![]() Join Date: Jan 2001
needed oil pan gasket.
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) Last edited by jc; 12-13-2004 at 07:12 PM. |
The high end Fel-pro gasket has allocation for oil dip stick on both sides. Its the premiuim gasket its around 30 bucks or so. Mine came with new oil pan bolts and everything its also a one piece gasket.
The ring and bearing kit that I got from Northern Auto parts had the oil pan gasket with the dipstick holes on both sides. I believe that it was a Mr. Gasket set.
Jim |
cool thanks guys i guss it wont be that hard to find . the regular parts stores only had left or right. and the local speed shop was closed today being sunday ill try them tomorow ill post a part # here if i get it just incase anyone else needs it.
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) |
use half a left and half a right.....btw wth is the point of 2 holes?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
Still drivin' a Rat Rod
Universal so it will fit any application is my guess.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
When I did mine no one could understand what I needed so I bought both a right & a left dipstick sets, that way I had enough. Brian
fel pro part # OS 34510 T . its for left or right or both and is reusable comes with new longer bolts, lock washers and snap ups (they are plastic treaded rods that push in through the holes to hold the pan up while you thread the bolts) it was $50 at the speed shop. i just checked $35 at jegs. oh well at least i can put the motor back in tomorow
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) Last edited by jc; 12-13-2004 at 06:56 PM. |
