Old 12-12-2004, 05:49 PM   #1
Locutus
Locutus's Avatar
Engine Knock on fresh rebuild
Today we fired up the engine for the first time and ran it thru the break in. After we came back from lunch we fired it up again and it has developed a knock when I let off the gas. It not advanced and I don't think it is detonation since it only seems to do it when you let of the gas. Any ideas what it could be??? I already fear we are doomed to pull the engine and have to start over
Locutus is offline   Reply With Quote
Old 12-12-2004, 05:52 PM   #2
cableguy0
check the torque convertor bolts and just look for anything else that might be loose if you dont find anything. dont risk it and just pull the engine out its cheaper to fix now than after a catastrophic failure. also does the engine have good oil pressure?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-12-2004, 07:21 PM   #3
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Thumbs up
I was also thinking flexplate bolts. Gotta use thread locker on those or they will come loose and create quite a racket.
Cat Fuzz is offline   Reply With Quote
Old 12-12-2004, 07:25 PM   #4
dwaite72lnghrn
If it knocks when you let off it might be a rod bearing. drain the oil and look for silver in it.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 12-12-2004, 07:35 PM   #5
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
My first thought was converter bolts also.Lets hope for something easy
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 12-12-2004, 07:40 PM   #6
cableguy0
i actually had something similar happened sounded definately like a rod knock turned out we blew the torque convertor b4 it got outta the garage power braking it. thought for sure the motor was done right then and there with 40 minutes running time on it till i unbolted the convertor
Old 12-12-2004, 08:07 PM   #7
rodnok1
rodnok1's Avatar
It could be a wrist pin, take the plug wires off one by one and see if it clears up. A rod bearing should double up.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 12-12-2004, 08:08 PM   #8
Broken_down?
I have the opposite from what cable was saying. Mine knocks when I get going about 35 to 40mph. The timing is not advanced dwell fine/rpm when I left off it stops knocking. I was just under the truck today and torque is not bad flex is not loose and the oil does not have any silver in it. any other ideas?
Rich
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 12-12-2004, 08:41 PM   #9
shortymac83
hmm...
shortymac83's Avatar
is it definitely coming from the bottom of the motor? what is the oil pressure? If it's coming from the top, maybe you have an oil passage plugged and a lifter or rocker isn't getting any oil. If it's coming from the bottom, check the flexplate and torque converter first.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 12-12-2004, 11:06 PM   #10
Broken_down?
mine personally has oil pressure in the 20 range for about 10 mins or so after sitting all night. Once it has warmed up it drops to 0 unless it is idleing down hill in which case it is about 5 to 10. Sounds like a lower knock.
Rich
Old 12-12-2004, 11:49 PM   #11
68C15
blood type; Retumbo
68C15's Avatar
was this a engine kit from Northern Auto Parts? I have done 5 engines so far with no problem until I bought from them for the most recent one. has a knock at first startup after oil change & also when sitting from a heat soak. also has a floating wrist pin noise upon decell about 1100-1500 RPM. they also sent me stock lift springs to go with the cam (cam is a 435-465 lift). I asked them what they will do & they said they would sell me new parts (no discount)
check the converter bolts before a complete tear-down.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 07-31-2005, 04:49 PM   #12
Locutus
Locutus's Avatar
Ok I haven't messed with this in months I was so frustrated by the engine knock. Could it be a stuck lifter if it only starts to knock after it warms up? Plus oil pressure seems a little low at idle but also only when it warms up.
Old 07-31-2005, 05:23 PM   #13
bigjimzlll
bigjimzlll's Avatar
If it only starts to knock after it warms up(thins the oil) then your looking at a rod bearing. It could be a lot of things..forgotton to tighten up the rod bolts..impropper installation of bearings...dirt under bearing cap(my vote) or impropper machine work.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 07-31-2005, 08:17 PM   #14
VetteVet
Msgt USAF Ret
VetteVet's Avatar
engine noises
Look at this website.
http://remanufactured.com/Engine_Noi...gnosis_101.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-01-2005, 05:57 AM   #15
GMC AMI
GMC AMI's Avatar
Always check bearing clearance on any motor before installing as a cheap insurance.
I learned this lesson of Hard Knocks!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
