Senoir Member
Engine ID help
I have looked everywhere I can on the interent and in my books, but can't find this engine block id #. It is 14814379 as best I can tell. The 3rd digit (possibly 8) is pretty much a blob of casting material, the others are fairly clear. When I bought the truck I was told it was a 350 crate engine purchased about 5 years ago now. Any ideas.......Thanks, Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
The closest thing that I can find is this....14016379...350...1977-1979...2 or 4 bolt main. www.mortec.com
I looked up in three sources and came up with the same thing as Randy.
Can you read the suffix code on the block pad in front of the right side head? That may help. JIm |
As they said you will need the suffix code on the right front ledge of the block it is even with the block deck in front of the head.
Senoir Member
I will check it when I get home from work, I'm on nightshift. Will post again hopefully before lunch time Monday. Thanks!!!
Senoir Member
OK, this is what I found on the passenger side front of the block below the head.... V0699800. The 0's are square looking, hope this will help. Greg
Senoir Member
ttt
Senoir Member
Where did everybody go??? No replies.......
