12-13-2004, 11:37 AM | #1 |
need auto / transfer for 70 k-10
looking for parts to change 4-speed 70 k10 to auto ( 350 )
12-13-2004, 01:16 PM | #2 |
"Ochre Ogre"
location is very important on the big and heavy things like this, where you at? I have the stuff you are looking for but unless you are close shipping is a killer.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
12-13-2004, 03:34 PM | #3 |
if you are interested, i may need some of the parts you are taking off. let me know if you want to sell anything. thanks
Ryan |
12-13-2004, 07:10 PM | #4 | |
12-13-2004, 07:50 PM | #5 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
12-13-2004, 10:34 PM | #6 | |
piney flats about 10 to 15 minutes on 11e southwest of bristol speedway or in other words in the hills |
12-13-2004, 11:06 PM | #7 |
Never thought about getting rid of the parts but I have most everything you would need, auto trans still connected to the t-case, cross member, mount for the t case and I think I still have the auto linkages. The drive shaft I have would be for a Blazer. Flywheel is still on the 307 that was hooked to it. I live in Northern Panhandle of WV.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible. |
12-13-2004, 11:43 PM | #8 | |
You already have the cross member and driveshafts you need for this swap... They are currently installed in your truck! You need the th350, adapter, and t-case. You also need an auto steering column and the shifter linkage from the column to the tranny. Try to get the transfer case shifter with the used parts. I did not and then I had to get a new shifter bolt from the dealer. They were different on the two NP205s I had. However the shifter was the same. Closely inspect any adapter you buy used for cracks. I've never seen a used one that wasn't cracked. I would also change the grease seals in the adapter and purchase and install a new drive sleeve while you have it apart. The sleeve and seals are what keep tranny fluid in the tranny and gear oil in the transfer case.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
12-20-2004, 10:47 PM | #9 |
thanks mrein3
sorry to be awhile getting back. mother-in law in hospital. i believe i solved my problem i bought a complete truck.
