12-13-2004, 04:25 PM | #1 |
Turn signal switch non/tilt
Are these hard to put in or should you hire someone for this job? I know you remove the steering wheel and the switch ,but what about the long wire how do you get that back down in the column?
12-13-2004, 08:48 PM | #2 |
The turn signal switches are not too difficult to change. The service manual has some pretty good instructions in it and if you like, PM a fax number to me and I will fax them to you.
The wires are a not that hard to feed through with the wire cover and connector removed. Jim |
