Removing old window tint
anyone know the best way to remove twenty year old tint on the windows?
--------- 72 SWB K10 San Diego CA |
May I suggest a razor blade and some sort of lubricant. Soapy water, windex, what ever, just so long as it stays wet while using the razor blade. My son made the mistake of using a dry razor blade to remove tint on his 77 C10. Left some major scratchs in the glass.
Make sure you are using brand new blades to. That will hel to not get any scratches.
WTB this ad
removing tint
I bought a kit at Auto Zone that had a spray bottle with some type of solution that softened up the tint and glue. Worked pretty good as long as you don't rush it. Allow the tint plenty of time to soak and it comes right off.
![]() Join Date: Apr 2000
i use a heat gun, and a razor blade.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
I used a razor blade and some wd-40 on my 72 Jimmy.
Just to be sure, are you trying to remove sprayed on tint, a coating, or tinted film that's adhered to the glass?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
I'd use a rock
#10 | |
#11 | |
thanks for the reply all. I like the rock idea the best.
#13 |
big rock
#14 |
Well, I used a new blade and some windex. Worked great. Thanks guys!!
#15 |
i took mine off with a grinder with a wire brush lol Riddla
68 GMC-Stripshow 70 Chevy Monte Carlo 72 Chevy Monte Carlo LOLO 72 Chevy Suburban Blurban 74 Vw Bug 78 Chevy k10 lwb 78 Chevy k10 swb 03 Cadillac Escalade-Duecesix 84 Cadillac Coupe Deville DeElegance ![]() ![]() B.O. A Lifestyle Money Cant Buy! Win,Lose, or Tie I'm a Raider till i die |
#16 |
Chance
![]() Join Date: Sep 2001
Cold Weather
A few years ago I was forced to remove my tint during the winter. As I pulled off the tint, to my surprise, the glue came off with it. It must've been -10 F without the wind chill but it worked better than any razor blade. So, if you're in a cold environmnet give that a try because you need to pull the tint off first regardless of the method you use removing the glue.
#17 |
The glue was the easy part. I used Goo Gone. I love that stuff.
