12-13-2004, 06:14 PM | #1 |
Can headers be shortened?
I have a bagged 68 C10 and the headers drop down lower than the frame causing a major headache when I'm too low in the front. Can they be shortened at a muffler shop or something?
12-13-2004, 06:21 PM | #2 |
it would be cheaper to just buy shorter headers. mid length seem to clear on most lowered trucks
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
12-13-2004, 06:24 PM | #3 |
Happy to be here
If it's metal, it can be cut and welded. Since it's pretty thin gauge, you better get someone that knows what they are doing though. Unless your just trying to save the money, I would buy a set of mid length headrs instead....
BTW- Welcome to the forum....
12-14-2004, 03:11 AM | #4 |
Headers are inexpensive! Replace with new shorty's.
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
12-14-2004, 06:06 PM | #5 |
What do you guys think of the headers from Early Classic?
12-20-2004, 01:33 PM | #6 |
Well the gf told me she'll buy me some headers for Xmas. Are these headers from Early Classic a good choice for $379?
http://www.earlyclassic.com/ProductI...1-6572HDRS.jpg http://www.earlyclassic.com/catalog.aspx "Early Classic is proud to offer the highest quality, American-made Small Block Headers available for 1967-'72 GM small block trucks. These new mid-length headers are swept rearward and dump below the firewall eliminating ground clearance problems for lowered trucks. These 16 gauge, mandrel bent beauties come with the only patented leak-free flange on the market. As an added bonus, a ceramic thermal barrier coating has been applied inside and out for years of trouble-free performance. (Pair) " Last edited by Cruz Lo; 12-20-2004 at 01:36 PM. |
12-20-2004, 01:55 PM | #7 |
67-72 Addict!
You can save alot of money thru Jegs or Summit.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
12-20-2004, 02:07 PM | #8 |
I'll take a look there. Thanks for the tip.
12-20-2004, 03:23 PM | #9 |
Early Classic sells Sanderson headers and IMO, they the best headers made. The quality is top notch.
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
12-20-2004, 04:08 PM | #10 |
Yeah I just broke down and bought some from Early Classic. Summit had some Flowtech 18 guage, 5/16" flange shorty headers for $439.95 and some Hedman 16 guage, 1/4" flange shorty headers for $325.55. I figured the 16 guage with the only patented leak-free flange on the market from Early Classic for $379 was my best bet.
12-27-2004, 02:45 PM | #11 |
The headers were delivered Christmas Eve. Now to get them installed. A local muffler shop quoted me $310 to install the headers, fabricate some headpipes, and connect them to the exhaust so I've decided that I'm going to try and do it myself. Do any companies make pre-bent headpipes that can clamp onto the headers and exhaust without having to weld? Is $310 a fair price? Seems way too high to me.
1968 C10 SWB, Fleetside, 350/350, FBSS Airbag Suspension Last edited by Cruz Lo; 12-28-2004 at 11:48 AM. |
12-28-2004, 02:01 AM | #12 | |
Call around and see what others are charging in your area.
72 Chevy C20 Longhorn 72 Chevy, K20 Custom Camper 67 Chevy, LWB, C20, 350/350, PS, PB, 65 Jag MKII |
01-23-2005, 05:12 PM | #13 |
I'm finally installing the headers today. The shop is charging me $90 to fab up some headpipes to connect them to the rest of the exhaust. Quick question though. What are these pieces called and should I buy new ones or can I use the existing ones that I have? They were between the headers and the motor. http://classictruckworld.tenmagazine...LOLO/82049.jpg
1968 C10 SWB, Fleetside, 350/350, FBSS Airbag Suspension |
01-23-2005, 05:49 PM | #14 |
yea you need new gaskets im kinda surprised they didnt come with the headers they are just header gaskets. do not use the paper ones they sell get a set of felpros that way you can leave the two end bolts in to keep the header alignment right and just drop the gaskets on. i have had zero problems with the fel pro header gaskets just check the bolts every now and again to make sure they are tight
01-23-2005, 06:48 PM | #15 |
A ha. Thanks for the suggestion. I just got back from Autozone with some of those cardboard gaskets you mentioned. Glad I didn't use them. Who sells the Felpros for the lowest price?
01-23-2005, 06:52 PM | #16 |
14.1 @ 96MPH
When I got my Sandersons from ECE, they came with instructions that explicitly said NOT to use gaskets - use RTV! Take a closer look in the box.
I loved mine and I'd still be running them if I hadn't gone for an LS1. The fit and finish is awesome on them, and obviously, clearance is not an issue.
Project1970 - LS1 Swap Complete! |
01-23-2005, 06:54 PM | #17 |
dont really know but auto zone or advanced auto should have em they should be around 15 bucks or so the part number is 1404 for a small block chevy also copper or aluminum gaskets are a good choice but a little more spendy
01-23-2005, 08:38 PM | #18 |
Nice catch Project1970. Thanks. The directions say to "place a 1/8" thick bead of Permatex #598B Ultra Black Silicone" but doesn't say where. Any ideas?
Here's my progress so far. The passenger side headers are removed and I'm stuck on the drivers side. I can't for the life of me figure this one out. http://classictruckworld.tenmagazine...LOLO/82053.jpg
01-23-2005, 08:42 PM | #19 |
pull the dipstick tube out and drop the headers out of the bottom you also might have to pull off the oil filter. your not going to pull them out the top without one hell of a fight i bet u pull the dipstick tube and it will fall to the floor
01-24-2005, 04:54 PM | #20 |
Hey, I am just curious if you want to sell your old headers. If so, how much??
Thanks, Travis
71 Chevy Long Bed (gettin' bagged) 84 GMC K1500 (Sold) 85 Monte Carlo SS white w/gray int. (being a dumba** and totaled it ) 85 Monte Carlo SS clone T-top (Sold) 72 Chevelle-tubbed 64 Buick Sportwagon |
01-24-2005, 07:00 PM | #21 |
Sorry man. Already sold them to a buddy of mine.
