Sloppy Steering
This may be a stupid question, but here I go ...
I have a '72 Chevy 4 x 4 with a rebuilt steering box. As I remember, I bought the rebuilt box about 20 years ago. My steering is getting a little sloppy now. I've been told that there is an external adjustment on the steering box that, when adjusted correctly, will take the slop out of my steering. Can anyone tell me if there is such an adjustment and how to do it?: I'm also thinking about replacing all of the tie rod ends, ect. Will this tighten things up or should the fanthom steering box adjustment do it? Thanks! |
20' Daredevil (Ret)
![]() Join Date: May 2003
Have someone get in the truck while you are under it. While they work the steering wheel back and forth, watch all the front end components. You'll probably be able to see where the slop is coming from.
If you suspect bad tie rod ends, maybe replace them first and you may not need to fiddle with the steering box. There is an adjustment nut, but it is generally thought to be a short-term band-aid fix for a worn-out box. IIRC, look on top of the box for a large slotted-head screw held in place by a locking nut. Try to hold the screw in its existing position while you loosen the nut. Tighten the screw very slightly, then tighten the nut. If the steering starts to stick, drag, or have friction, you have gone too far and will need to back off a bit. Be very careful on your test drive, because if you get it too tight, the steering will drag and won't want to return to center by itself. A little trial and error will get it right. Good luck!
Thanks! I'll check this stuff out. You've been very helpful!
I recently rebuilt my 71 K20 front end.
New tie rods, new ball joints, rebuild power steering box. Guess what? Yup, still sloppy steering just as bad as before all the rebuild. I don't get it. I figure that the rebuild NAPA gear box -- is not all that "rebuilt". If I where to do it again I'ld hunt down a NEW gearbox.
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
Junior Member
![]() Join Date: Feb 2004
I had about a 6 in "slop" in my steering, I replaced the gearbox and now it is great
Bill Toothaker 72 K20 FSLB 63K FS:86 Mercedes 560SL 63 Ford F100 51 Willy's Jeep station wagon w/64 289 Studebaker 68 Honda SL90 1500 miles Chevy 6 cyl street rod 2011 Nissan Murano cross cabriolet Cabins for Rent Lake Winnipasaukee, NH |
Try gmpartsdirect.com or partszoneonline.com for new parts. Give them a call, not everything shows on the website.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
OBS guy
Guys, guys, same problem, here was my fix, and it had dramatic results. Stocker was on the right track, but you have to be very careful when adjusting the steering box to ensure you are doing it right.
My steering was sloppy and it was tracking the highway and was quite fatiguing. Until... I did a lot of research on adjusting the steering box. After concensus from multiple sources, I tried the adjustment. Jack the front axle off of the ground so the truck steers freely. Turn the wheel all the way clockwise to lock. Mark the steering wheel and steering column as a starting point- anywhere is fine, just so long as the wheel is at lock. Then slowly turn the wheel counterclockwise and CAREFULLY count the revolutions from lock to lock. I think my 71 K5 was 3.75 revolutions lock to lock. You then divide the lock to lock revolutions by 1/2. In this case, the center of wheel travel is 1.875 turns from LH or RH lock. Turn the wheel back 1.875 turns to center the steering box. Then, slightly loosen the outer holding nut on the gearbox while holding the allen head. Tighten the allen head slightly until it snugs up slightly. Hold the allen head and retighten the outer holding nut. What it is, the main gear in the box is an arc. The adjustment must be made at the top of the arc OR if you do not adjust at the top of the arc it overadjusts and the mesh will be too tight and actually lock when you are steering. Not sure if it makes sense or not, I can see it in my mind! ![]()
88 Suburban Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear, Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more |
OBS guy
Oh, and my steering feels amazing now... Changed the whole driving dimension and made it safer and more enjoyable.
I currently have about 4" of play in the column on the 72. When you are sitting still, you can float the wheel back and forth 4". I am swapping out the gear box and installing the pump for power steering this spring, so I hope it eliminates the slop
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Summit can get new steering boxes for a little over $300 dollars, this was for a manual steering truck.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
DOn't forget to check your wheel bearings. A good portion of my slop was from well worn & really needing adjusting wheel bearings.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
This is all good stuff. Thanks, all, for the information.
#13 |
Still drivin' a Rat Rod
Idler arm,and pitman arms are things that don't get much attention when frontend work is done.Make sure to check those out as well.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
