motor mount question
this is a smallblock 350. on a 1970. i know the top part of the motor mounts bolts to the frame with 2 bolts. is the bottom part, that touches the crossmember supposed to be bolted down to the crossmember part? mine are not and it seems like my shifter moves alot and i was wondering if this would cause this...
70 longbed 496/th400/Ford 9" |
Got Light Emitting Diode?
not a pro but i think that there is one bolt that holds them to the saddle of the crossmember
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Watch out for your cornhole !
![]() Join Date: Jun 2003
It's a 3/8 bolt with a nut underneath the bottom of the crossmember. The nut's hard to get to, is probably why they left it out.
does it make a difference? like will it not move around as much if i put these bolts in?
#5 | |
thank you! ill have to get to work on these to get them lined up
