Old 12-14-2004, 10:21 PM   #1
Newt408
changing out a/c heater control pannel
What can I look forward to cussing about when I swap out the a/c heater control pannel? Does it control the heater with vaccume lines, cables or wires? Mine wont switch from the floor vents and when I pull the lever to off it makes a sucking sound until I wiggle it around.
The way of a fool is right in his own eyes:but he that hearkeneth unto council is wise. Proverbs 12:15
Newt408 is offline   Reply With Quote
Old 12-15-2004, 01:22 PM   #2
KShortell
KShortell's Avatar
Changing out the heater control is pretty easy IF you also remove the radio. Of course, you do need to pull the dash bezel. There is a cable connection for the blend door control and a vacuum connection for the selector.
I changed mine out last year. It's no problem if you pull the radio to get better access.
Good luck!
Semper Paratus
KShortell is offline   Reply With Quote
