oversize tire balancing
i have 39.5 inch super swampers on my truck and it vibrates very badly going down the road. the tires have never been balance b/c i was told you really couldn't balance a tire this size. what opinions do you guys have on balancing oversized tires?
#2 | |
Majician
Geared for Collision
use what tractor trailers use, its like sand and comes in little bags that self balance.most tire shops have it. i would use two bags in each one. also some people prefer bb's. my tires arent as big as yours but have swampers and they couldnt balance so thats what i have done. ive heard it works pretty well but havent got it back together yet.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
#4 | |
Majician
It is called "Equal", and not as many big trucks use it as you think. The local tire shop here doesn't even bother selling it anymore. Most big trucks don't even balance their tires. |
![]() Join Date: Feb 2001
I have alsways used stick ons and have never lost any. I always use duct tape over them and it seems to work good. Everything needs to be clean. They sell a product now just for this. You add the little balls through the valve stem I believe and the bags of balls are sold by weight. I couldn't find the link but will look again. I have heard of golf balls exploding and the bb's turning to powder (Rust).
OBS guy
Hmmm... There was a shop I went to to balance my Mickey Thompson 39s on my old GMC (18" wide!!! on 14" wide rims)... Won't hurt to call around. Someone will balance them for you.
I think I got help at a Supershops... There is only so much a balance at the rim will do for those big boys though. They can add weight and maybe line up the low center on the tire to the high center on the rim and such. Swampers are no punk!
88 Suburban Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear, Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more |
Mike
I,also have not had any of the stick-on wieghts come off.Just make sure they clear Your caliper,if you have disc's.As far as TT tires,I never balaneced my rear tires.There was a local shop that would shave the high spots off.It worked real well.They balanced the front wheel/tire while mounted on the truck.The frontend machine was in a pit.You drove over a "bridge"and onto a set of rollers.It would high speed balance the front wheel.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Best way is to either have them pad balanced, use golf balls, BBs, or water/anti-freeze mix.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
1972 has it right. Internal weight pads affixed to the inside of the tire carcass does the best job of fixed-weight balancing tires, especially large ones. Affixing the weight farther out from center has the benefit of needing less weight than wheel rim mounted weights (physics
![]() Hunter Engineering makes the GSP9700 balancer that makes the tire "ride" on a roller under weighted pressure while checking for balance abnomalities. Simulates weighted on-road conditions. Prolly the best balancing method by machine. Hunter's site has a GSP9700 locator.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
on swampers that may not work too well as when they spun mine it said need almost a half pound of weight. my wheels and tires were new and they tried unmounted and remounting with same result. overall swampers arent good for street driving anyway. i figure most speed mine will see is 45 mph so i dont think it will really matter. if i was planning on ever going on the highway i wouldnt have got swampers. a friend of mine had a set and he drove his to work like 20 miles on the highway up to 65 mph and they split apart within a week.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe Last edited by Budweis; 12-16-2004 at 03:43 AM. |
'87 V20 4x4
find a shop that still uses a bubble balancer they are very accurate and will handle oversized tires.... Doc
'86 K5 Blazer 4x4 FOR SALE '87 v20 4X4 '99 S10 Blazer 4X4 ![]() ![]() |
#12 | |
#13 |
I've had Swampers that take as much as 16 0z's. It can be done, and for th most part drive pretty good.
#14 |
user # 2756
![]() Join Date: Jun 2001
What about having the tires "trued" first. Where excess rubber is scrapped off. I think there is a shop here in SE VA that can "true" tires.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
#15 |
A friend of mine has 33" Boggers and he used normal lead shot. (the kind you use to reload shotgun shells). Not sure what size though.
I think he used 10oz. in each tire. He says it's working pretty good so far. (On a side note, he also says those Boggers cost him a few mpg compared to his "street" 265-85-16 tires).
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
#16 | |
#17 |
" SHOW ME"
we balanced my 39x18 inch mickeys ,, my 39.5 boggers seem like they are balanced really good with no wieghts , when me and my brother worked at the local neal tire we balanced all of those big tires , find a shop that has a semi tire balancer , they will do it no problem if theyre any good anyways ,,,and yes 1972 , the big trucks do balance theyre tires , and no swampers are not pos tires lol , if they were they wouldnt sell some of them for upwards of 400 dollars per tire or at least people wouldnt pay that if they were
#18 | |
Majician
Some big trucks do balance thier tires, about 5% of them. The other 95% don't even worry about it. I have never seen a trailer tire balanced unless it was on a fancy stainless sided spead axle super trucker chicken-mobile trailer. Swampers sell for $400 and people buy them because Sears RoadHandlers sometimes won't handle the tasks that Swampers are needed for, and what are the other options? Swampers don't have much compitition in the marketplace, that's why they rape the consumer. They get $400 per tire because people need them for a certain terrain, not because they are a high quality round tire that is capable of being balanced, because they are not. Interco uses the same molds for the TSL's that they used in the early 80's, all of the heating and cooling of the mold has warped them bad enough that it is impossible to get a round tire from them. That's why the newer Interco tires such as the Boggers and Iroks are much more round and easier to balance. |
#19 | |
im not sure which type he has a prob balancing but the ones i have are boggers.
#20 |
" SHOW ME"
sorry 1972 , i thought you were talking about steers or drives on a semi not the trailer , we balanced very few trailer tires
#21 | |
Majician
The tires that I have are 36/12.50-16.5 TSL SX's. They aren't really very big and should not ride as rough as they do. I had mine balanced when they were new and they balanced perfectly, but I could see as the tire spun on the balancer that it was very out of round, which will never ride smooth even if it is balanced. As JIMs70GMC said you can have the tires "trued", where they will spin the tire and make it round by shaving down the high spots. I bought mine for traction though and can't justify spending even more money to loose a 1/4" of tread or more so I just deal with the rough ride. A friend of mine had some new 44's trued once and lost about half the tread on one side of one of the tires and it took over 6 pounds of weight patches inside the tire to balance it (you have to compensate for the weight of the rubber shaved off) but it did ride nice ![]() |
#22 |
Hey, 4x4poet & jims70gmc Have the answer. Ive read several times that 4wheeler & 4wheel & off road used those exactly & said they work great. Thats what id do cause i cant stand an out of balance tire.
All my trucks are gone now. ![]() ![]() |
