12-15-2004, 03:57 PM | #1 |
71 DELUX
beefed up (factory) trailing arms ?
OK, so it has been reported that the 3/4 ton (?) trucks had reinforced trailing arms, with metal plates on the top and bottom? Is this correct? Was it a factory option, or standard on certain trucks? What's the deal, any pics?
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
12-15-2004, 05:11 PM | #2 |
IIRC they are std on ¾ton.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
12-15-2004, 05:30 PM | #3 |
Got L.E.D.s
I've never heard of any regular trailing arms ever failing.
Bagged 1972 2wd Blazer http://www.earlyclassic.com/home.aspx |
12-15-2004, 06:12 PM | #4 |
I guess they might help in twisting, but other than that I guess they had some extra steel laying around. I just welded the seams on mine completely shut instead of buying those aftermarket plates.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
12-15-2004, 06:37 PM | #5 |
its all about the +6 inches
Come to the rust belt...plenty of trailinf arms fail.
12-15-2004, 07:22 PM | #6 | ||
On my 67 & 68 I just put a small 1" weld about every 6" @ the seam & completely weld the rear (behind the u-bolt).
12-15-2004, 07:30 PM | #7 |
"Ochre Ogre"
This wasn't a big ol' heavy piece of reinforcement. It was a thin piece of flat steel tack welded to the top and bottoms of the trailing arms. It was more to prevent rust which forms between the 2 halves from seperating and breaking the welds that held them together. In the great icey North you can find trailing arms that have seperated 1/2" or more due to rust.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
12-15-2004, 07:41 PM | #8 |
IIRC, the ones I put on my 64 that were plated had the same gauge metal as the arms themselves.
12-15-2004, 07:49 PM | #9 |
That's what I did on my trailing arms was just weld four 1.5 inch stitches and they should be fine. I had heard that they may twist under horsepower so I did it just in case.
12-15-2004, 08:29 PM | #10 |
Prevent rust, lol. The trailing arm on the driver's side of my truck has rust in between the plate and arms, and the rust is pushing the plate away from the trailing arms. Should I cut it off, treat the rust, then weld it back on? Not sure any kind of rust killer would get in between 'em. The one on the passenger side looks good though, kinda weird. Not trying to hijack the thread here, just need help from someone that's done this before.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
12-15-2004, 08:32 PM | #11 |
I drilled out the rivets, blasted themand painted the insides and weled them back together. Crappy design the top just holds water and crud. I welded them solid top and bottom.
12-15-2004, 10:47 PM | #12 |
Don`t think the factory was thinking of rust prevention when using those plates.The rust came later.Were the plates just on 3/4Ts?
12-16-2004, 03:17 AM | #13 |
I'm surprised the aftermarket has not made heavy duty trailing arms. Moreso than 3/4 ton arms, I mean. I've toyed with the idea of converting my C10 Sub to 4wd using the trailing arms flipped on top of the axles, but I've been leary of the arms' strength and the one, pass-or-fail, u-bolt. Good size u-bolt, though.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
12-16-2004, 04:32 AM | #14 |
I'm pretty sure someone will be coming out with some real soon. Also I believe Ed @ Mothertruckers tried to get some people together to get a set made but didn't get enough interest. I wouldn't weld them up solid as they need some flex but do like SCOTI did and run some stitch welds. I am putting a 1/8" plate on top of mine where the axle sits.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
12-16-2004, 08:20 AM | #15 |
Why do they need to flex?
12-16-2004, 09:20 AM | #16 |
Early Classic Enterprises makes a trailing arm re-enforcement kit.
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
12-16-2004, 09:45 AM | #17 | |
Happy to be here
12-16-2004, 10:46 AM | #18 |
71 DELUX
So, they were 3/4 ton standard and 1/2 ton options from the factory. Just wondering because my truck had one of each on it when I got it, so I am thinking that one of them was replaced with the re-inforced version.
12-16-2004, 01:19 PM | #19 | |
12-16-2004, 02:36 PM | #20 |
71 DELUX
so this may sound stupid...
BUT...
To save flexibility AND keep the halves together, could some heavy duty bolts/nuts simply be used, say ten inches apart from one end of the arm to the other, fastened right through the middle, keeping the halves together? OKAY, tell me how bad this idea is.
12-17-2004, 04:34 AM | #21 |
That would work but IMO wouldn't look too good. But I got this "it's got to look as good as it operates" hangup and that's just my opinion. A few stitch welds would be more than sufficient and keep the trailing arms together for hopefully another 35 years.
