Old 12-15-2004, 08:18 PM   #1
Chevyguy111786
doors hard to shut
I have a 78 1/2 ton lwb and my doors have been hard to shut since i bought the truck. they aren't lined up right and sag a little when open. how can i go about fixing this? do i need new hinges or can i get some kinda of rebuild kit? can i shim the ones i have? can the striker be adjusted also? if so, how would i go about doing this.
Chevyguy111786 is offline   Reply With Quote
Old 12-15-2004, 09:24 PM   #2
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
It's a GM, what do you expect?
Seriously, there are some guys on here that slip a piece of plastic or vinyl tubing on the striker and it lines up great...help me out here.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 12-15-2004, 09:36 PM   #3
useRc10
useRc10's Avatar
i think they can be shimed (at least thats what we did on my '72...the '85 needs some work since you have to "follow through" in order to get the door shut...if anyone knows a trick, i'd be interested
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 12-15-2004, 09:41 PM   #4
Lynx
Lynx's Avatar
Well first you have to find out which problem it is your having. If your hinges are worn it will sag. If your door is miss aligned it will cause problems. Your striker can be miss aligned and the little plastic tube on the striker can be worn or broken also causing problems.
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 12-15-2004, 11:38 PM   #5
Chevyguy111786
hmm...i don't think i have a plastic tube on my striker....interesting, and the doors do sag...so maybe a combination of both?
Old 12-15-2004, 11:56 PM   #6
76bonanza
76bonanza's Avatar
Get new striker or just the plastic tubes, mine are the same and with new strikers they are 90% better.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-16-2004, 12:09 AM   #7
useRc10
useRc10's Avatar
do you have to order the plastic tubes through a vendor or do they have them at parts stores?
AIM: Auntjoedadda
Old 12-16-2004, 12:15 AM   #8
76bonanza
76bonanza's Avatar
The help section at any autoparts store should have them.
1968 c10
lowered 3" 4"
Old 12-16-2004, 12:18 AM   #9
leastbay
they have them at the parts store but lemme tell you the problems i had my drivers door needed new hinges, you can tell by lifting up on the door when its open and you sill see the pin move around in there , autozone sells a repair kit so installed 2 new ones on there , but the problem i ran into was that now that my door didnt sag anymore it didnt line up now i would save yourself the trouble and take it to a body shop seriously , you will be pissed trying to line that thing up
leastbay is offline   Reply With Quote
Old 12-16-2004, 12:32 AM   #10
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I vote worn out hing pins and bushings. If those are bad its possible that the hindge itself also had ware on it due to the pins and bushings not being replaced sooner. You dont have to open the door all the way to see if its them. I usally just open the door about 6 inches and then lift up on the door handle. The door will either move or it will pickup on the cab raising that side of the truck. When I lift the door I somewhat wiggle it up and some to kind of determan how much play there is in the door. Trying to adjust the door with wornout parts is just going to be that much more of a chore when it does get replaced.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-16-2004, 01:19 AM   #11
Destructo
I put new bushings and pins in my hinges and new strikers or adjusted them properly and now my passenger door closes like butta, now I need to work on the driver side door.
I found that the biggest problem was the striker being to far in toward the cab.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 11-16-2014, 04:58 PM   #12
Ronald29609
Re: doors hard to shut
The body shop returned my 67 Chevy truck and the passenger door is misaligned. The hinges are rebuilt and the doors are new aftermarket pieces. The striker doesn't line up and you have to really slam the door to close it. The gaskets aren't on yet. The truck isn't drivable. Can one of you experienced guys help me fix this? It's my 1st built and I am in over my head.
Thanks.
Ron (the retired guy)
Ronald29609 is offline   Reply With Quote
Old 11-16-2014, 08:12 PM   #13
swissarmychainsaw
To: Chevyguy111786
There are three things that can be wrong here, there are lots of good youtube videos on this too. Sadly I have had each one of these on different vehicles.
https://www.youtube.com/results?sear...uck+door+hinge
1. Your door striker is mis-aligned; needs plastic bushing.
This is not your problem because you said your "doors sag when opened".
Well you probably have this problem but this is the LAST step in your repair.
2. Hinge Bushings
If doors sag, it's likely due to the bushings being bad.
HELP sections carry both the hinge bushings and the strikers/bushings.
(total less than $20
I have found that once you replace the bushings you need to then align the door. This is fairly tricky (see links above) but it's the right way to get your door to "shut like new".
So: bushing, alignment + sticker/bushing = easy open/close
My advice though, is if you are going to all this trouble, just replace the hinge too. They are only $20!
3. Cracked door.
Symptom: Gross door sagging. You won't be able to open/shut it with out "lifting" up on the door (or slamming really hard).
Look for wear on the bottom of the door sill (where you step in). If you
door is wearing a bit hole there, or touching the B piller, check for this.
Open both your doors, and look carefully where your hinge attaches. It's common to have a little crack there. Remove door, get it welded (then replace the bushings and striker).
swissarmychainsaw is offline   Reply With Quote
Old 11-16-2014, 08:15 PM   #14
swissarmychainsaw
Thanks.
Ron that sucks. Take pics and start a new thread, since yours is a 67 and uses a different mechanism. I have not dealt with this type before.
What about taking the truck back to the "body shop"? What did they do?
Maybe you need to find a better body shop?
From what I have heard the "aftermarket" sheetmetal might not fit as well as the stock stuff. However you would think a body shop could figure it out.
I KNOW you can. You have the internet and you're retired! :-)
Start a thread and these guys here will help you sort out your truck.
You can do it!
Old 11-17-2014, 11:39 AM   #15
1774btcrew
1774btcrew's Avatar
I was going to bring up the cracked door thing as well. These doors are notorious for cracking at the hinges. They were flung open and over extended over the years. This is the main thing I check when I go to the wrecking yard to find a replacement door. Even if your doors are closing fine, look for cracks around the hinges. Many of these trucks have this problem.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
