Fender Question
I found a good passenger fender at a local junk yard. It's off of a 67-68 GMC suburban. It will fit my 72 GMC Truck right? it's got a small dent and minimal rust in the trouble spot (under Battery). talked him down to $65. Just making sure it will work with my eyebrow trim
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
user # 2756
![]() Join Date: Jun 2001
It will fit. a 67 fender has no side marker light, 68-72 do.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
its all about the +6 inches
It'll fit, however, I wonder if you can get one cheaper, with less rust.
I wouldn't pay that much for anything with a rust hole. |
It's mainly surface, nothing that a little sand paper can't handle. And it does have a sidemarker so it must be a 68. the hoods sloped so i new it was one of the years.
