OzarkHillbilly in Atlanta
installing new turn signal switch
Got my new turn signal switch today and gonna put it in tomorrow (as long as the chevy dealer has the straight to horseshoe adapter i need)
I know the basics of doing it, but are there any tips or tricks I need to know. Or any "Dang It, WHY THE HE** DID I DO THAT" things I might run into. thanks guys
72 custom/10 LWB 68 Longhorn C20 Custom Camper (sold) |
67-72 Addict!
I like to make sure wheels are dead straight ahead then disconnect battery. I always take the adapter and cut off the end of the straight part that has no connectors. You will need a steering wheel puller. Remove the screw holding the lever. Be very careful removing the cancel cam brass contacts (there are 4 tiny springs under those). Now is the time to replace the cam if it's cracked. Push the hazard button in and slide the switch up and out on an angle because it's a tight fit. You will need to remove the metal column cover on the underside of the column to access the wiring. Unplug the old harness and pull the wires up thru the cup. Take the new harness straight end and slide it back thru the cup very carefully. I'm going on memory here so I might have a step or two out of order or missed a step. If you have trouble just ask and we will guide you thru it.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
