Old 12-16-2004, 03:11 AM   #1
super72bb
Anyone who has changed control arm shafts
Hi there,
I have a question... I layed the new Lower control arm shafts out on the bench tonight, and I noticed that they are different! They seem to be exact in their width but one has a longer thread run (About 3/8") on both ends, The shafts are not made by a different company or anything it almost seems like it could be right. Can anyone confirm if I do have the right set? If need be I could snap a photo and get it online tomorrow to show the difference. The passenger side control arm is the only old one I had around to compair it matches up exactly with one of the new control arms I was wondering if the drivers side was different?
Thank you
Curt
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK.
My build thread:
http://67-72chevytrucks.com/vboard/s...=1#post7120181
super72bb is offline   Reply With Quote
Old 12-16-2004, 03:39 AM   #2
ChevyDude
I just changed out my Drivers side lower and upper and will do the passenger side this week end. What brand did you buy? The swap is pretty easy if you know the right steps. Yes.....I will explain more if you need.
Drivers side is the same.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 12-16-2004, 11:34 AM   #3
jay6891
Car Knocker
jay6891's Avatar
My truck needs the same thing done to it. Has been parked for about a month now. Where did you find the parts, price.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 12-16-2004, 11:47 AM   #4
ChevyDude
Advance Auto has all TRW stuff...Auto Zone has the same parts just there brand Dura Last.
Alex
Old 12-16-2004, 12:01 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
shafts? do you mean the bar that the bushings connect to? I know that on my 67, the 67 ball joints are smaller than later years. I swapped my front suspension for a 71 with disks. From what I can remember, I believe the "shafts" were the same length on both sides and on both suspensions....the 71 had a bent lower cotrol arm on the pass. side so I had to use my 67 lower control arm. truck rides like a new one!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-16-2004, 12:07 PM   #6
gr8scott51
gr8scott51's Avatar
Probably just lack of quality control in Taiwan or someplace.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 12-16-2004, 12:33 PM   #7
ChevyDude
I would reccomend you guys that are going to do this swap....Buy TRW or MOOG parts...Made in the U S of A and just better in my opinion.
Alex
Old 12-16-2004, 12:35 PM   #8
1969K10
1969K10's Avatar
When I replaced those parts on my '72, the passenger & driver side were identical.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 12-16-2004, 12:36 PM   #9
super72bb
Here is a picture...
The shafts are exactly the same length and Diameter. But as you can see the shaft closest has more of a thread run than the other.
Is this just poor quality control?
Thanks again
Curt
My build thread:
Old 12-16-2004, 01:05 PM   #10
rodnok1
rodnok1's Avatar
They should be they same. I would use TRW or Moog parts also. AdvanceAuto carries TRW, The only problem I have had is missing parts from the boxes, which is why I buy local so I can take them back.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 12-16-2004, 01:12 PM   #11
chevybill
chevybill's Avatar
They are available from summit.
I recently purchased a complete front end rebuild kit from summit, not as a kit but all the individual parts.
And guess what guys, it is all moog and moog is being made in mexico.
So maybe the old chevy will be "spicy" when I get finished with the front suspension.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 12-16-2004, 02:05 PM   #12
Fred T
Cantankerous Geezer
Fred T's Avatar
I'd take them back. One of the two is wrong, you can compare to your old shaft to determine which. I put Moog shafts on last summer, only problem was a missing seal, which my parts man took care of for me.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
