Old 12-16-2004, 11:39 AM   #1
bagged81
Signals in the bumper.
bagged81's Avatar
Roll-on Bedliners?
I will try this topic in this forum. I ran across this stuff that JCWhitney sells, Herculiner, anybody used it and satisfied with the results? Or perhaps can anybody recommed another ROLL-ON bedliner?
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 12-16-2004, 11:42 AM   #2
PHOENIX
If you are going to do it strictly for cosmetics its not bad.
If you actually want to be able to throw stuff on it you better get the real thing.
I used the spray in kind, dupli-color brand and it looks ok, but isnt very thick.
The roll on kinds are thicker and stronger, bot nothing even close to the real spray in liners.
I know many who have done both ways and all agree the the real thing is better all around.
Both will fade in the sunlight.
The spray in that I used was in spray cans, so you cant expect too much out of them. I prep'd it well and spray in twice the recommended amount and its still thin and scratches easy. It does look pretty good though. When I did this it was because I had a plastic liner that didnt fit well and I was afraid of rust in the bed. I pulled the liner and everything looked pretty clean, so I decided to do a quick cheap spray in for now. Here is the only picture I can find that shows the bed liner.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 12-16-2004, 12:03 PM   #3
bagged81
bagged81's Avatar
Yea, mine will be for cosmetic purposes. I never got the inside of my bed color matched because of the price of the candyapple and because I was hauling stuff so I left it primered. I just want to kind of finish it off so that it looks good. It does not haul much these days.
Yours does look nice but I want to stay away from the spray stuff.
Jeff C.
Old 12-16-2004, 12:52 PM   #4
PHOENIX
Yeah I wouldnt recommend the spray in a can type like this.
Its hard to tell in pictures, but the problem with the roll on type is the texture doesnt look too consistant.
There is a do it yourself spray in liner that required a paint gun.
I havent seen one done this way so I dont know how that works.
But I know the can doesnt have enough to do one truck bed.
Old 12-16-2004, 02:12 PM   #5
mhicks
mhicks's Avatar
My son has a kit (Herculiner) that he bought from Autozone and gave like $120.00 for it. He would probably sell it to you for half that. He sold the pickup he was going to put it in and bought one with a wood bed and doesn't need it. He also bought an extra can with the kit so there would be enough to do a full side bed. Send him a PM if you are interested. CHEV74
mhicks is offline   Reply With Quote
Old 12-16-2004, 02:25 PM   #6
1Ton
1Ton's Avatar
I did a roll in liner in my truck and If I was hauling more than groceries and a stroller I would probably do it again so it was thicker. But it also costs a third of what it would cost if you took it to a rhinoliner dealer to do. I did mine just so the paint wouldn't scratch and then rust. For your application the roll in one should be fine.
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 12-16-2004, 02:52 PM   #7
bagged81
bagged81's Avatar
Tell him he has a pm.
Jeff C.
Old 12-16-2004, 02:59 PM   #8
useRc10
useRc10's Avatar
do y'all think the roll-on stuff would work ok for a blazer (fiberglass) top...i plan to paint it in the spring, but not sure what i should use
Thanks, -Nick
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 12-16-2004, 03:05 PM   #9
bagged81
bagged81's Avatar
Are you talking about on the inside? I dont see why not. Here is the product description.
lol, There are hundreds of uses.
Jeff C.
Old 12-16-2004, 03:11 PM   #10
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
My buddy did it to his truck and it peels up.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 12-16-2004, 03:22 PM   #11
useRc10
useRc10's Avatar
no, i'm painting the outside...the black is faded and has been scratched from tree branches in a few spots...its says for camper shells and boats so i assume its safe for fiberglass
AIM: Auntjoedadda
