12-16-2004, 09:00 PM | #1 |
Professional Grade
Starter fusible link amperage?
Hey fellas!
I gotta rewire a Dodge mini-van so the starter starts off a push button rather than turning the key (they broke the ignition cylinder, so they can only get the van to the on position and not to the crank position). I need to know how many amps of a breaker I need to put between the starter solenoid and the battery?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
12-16-2004, 09:16 PM | #2 |
Professional Grade
Oh, and since I've got the attention of the electrical gurus, why do my interior lights come on and something under my dash make a sick buzzing noise instead of my horn honking? :p
12-17-2004, 06:00 AM | #3 |
ROCKET POWER!
To be on the safe side, make sure the fusible link (or fuse) you wire between the button and solenoid is rated at 40-50 amps.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
