Old 12-16-2004, 09:48 PM   #1
1978steven
1978steven's Avatar
Power Steering Conversion Question
I'm looking to do a power steering conversion on my 1971 Chevy. I have found a complete setup (gearbox, mounts, and pump) from a 1979 Chevy. Will this bolt directly up to my truck or should I hold out for a setup from an earlier truck?
Thanks for the help,
Steven
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
Old 12-16-2004, 09:56 PM   #2
john
member #16
john's Avatar
The later one will have brackets and pulleys for long water pump. John
john is offline   Reply With Quote
Old 12-16-2004, 10:00 PM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
the box will work fine, but as posted above it is for a long water pump
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 12-16-2004, 10:07 PM   #4
1978steven
1978steven's Avatar
Could I just go to a long water pump or would I need to get a different steering pump?
2004 Tahoe LT
1971 Chevy C10
Old 12-16-2004, 10:51 PM   #5
neonlarry
neonlarry's Avatar
To go to long water pump you would also have to change alt/AC brackets, crank pulley. Better to just get different steering pump bracket the pump should bolt up fine.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 12-17-2004, 03:04 PM   #6
1978steven
1978steven's Avatar
So I would just need a set of brakets for the pump and short water pump.
2004 Tahoe LT
1971 Chevy C10
Old 12-17-2004, 05:28 PM   #7
neonlarry
neonlarry's Avatar
Yes, and yours should already have a short water pump (unless someone changed it). Difference between short and long pump:http://67-72chevytrucks.com/vboard/s....php3?t=109160
Old 12-18-2004, 01:30 AM   #8
longhorn71
longhorn71's Avatar
yes you can.but you need to move the alternator to the passenger side.
longhorn71 is offline   Reply With Quote
Old 12-18-2004, 02:28 AM   #9
pissonNOS
senior member
pissonNOS's Avatar
look for a bracket out of a late 70's early 80's van it worked fine for me
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 12-18-2004, 08:42 AM   #10
1978steven
1978steven's Avatar
Thanks for the help everyone. This has really helped me out and saved me some money now that I know what parts I'm looking for.
Steven
2004 Tahoe LT
1971 Chevy C10
