Registered Smarta$$
63 gmc 2x4 to 4x4?
i have a 63 gmc w/ a bb v6 and sm-420 i want to make it a 4x4. i have done some research and searched the boards i know it is easier to do a chassis swap instead of a front cross member swap, but what year would be easier to swap w/ little mods to body mounts, i was thinking of a newer chassis and keeping the v6 and sm-420. what t.c. would work w/ the sm420?
thanx, jim
63 GMC custom going to be slammed ![]() ![]() |
user # 2756
![]() Join Date: Jun 2001
rockwells were bolted behind the sm420. I also believe adapters are made to adapt the sm420 to newer transfercases, advanced adapters for one. You could mount a divorced transfercase though, might be easier.
If the 60-66 frames are close to the newer frames, you could probably remove the front spring brackets from a newer truck and mount them to your 63. Did 60-66 trucks have different engine mounting positions? That will dictate wether the engine needs to be moved back for front diff/oil pan interference and driveshaft length. The v6 was mounted in the 67 and up frames so if you started w/ say a 71/72 frame you could fab your own body mounts.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
I have a 1964 short bed 4x4 GMC Which is a pretty rare bird these days. I am parting it out, all but the cab. So if you decide to go this route feel free to E-Mail me @ intensete@hotmail.com. the truck came with a factory 4" lift and was on the road a year or so ago with 12.50x35x15 BFG Mud Terrain T/A'S. I presently have way too many projects going right know and the old lady is screeching daily. SOUND FAMILLIAR
My roomate's 63 chevy is undergoing that build up. It's been converted to leaf springs front and rear and plans call for a divorce mounted transfer case, new brakes, and a few other things. We've got the suspension where it should be and just have to do a lot of drilling and/or maybe welding to make it permanent. We still have a lot to do and hope to get the rest done in the spring.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
