Go Jack car dollies for sale
Still cleanin shop...
This is 1 pair of Go Jack 6000lb car dollies. Ya just stick em under the wheels and jack them to raise the tire off the ground. (You guys know how they work). Each one needs 1 caster wheel to be usable. The other 3 casters seem to be in working order. I bought them thinking someday I might get a new concrete floor in my shop but I can't see that far in the future right now. ![]() ![]() ![]() Here's the bent casters, (1 bent caster on each dollie). ![]() ![]() I've looked around on the net and can't find these cheaper than $350 a pair so I'd like to get $175 out of them, (considering the bent casters and broken handle).
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey Last edited by 454_72_4X4; 12-17-2004 at 12:16 PM. |
I use the flat ones, but you have to jack the wheels up to place them.
You're right replacing the casters and fixing the handle shouldn't be a problem.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
Cowboy Fan for Life!!!!!!
They are worth it guys. We had these when I was doing bodywork full time and they are great. I wonder though, if they will work on a lot of todays 18 & 20+ inch wheels?
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
#4 | |
If you're lookin up info on them, don't forget these are the 6000lbs, (1500lb per), not the 5000lbs. Another FYI; They weigh almost 40 lbs. EA.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
Just found this;
http://www.tooltopia.com/index.asp?P...OD&ProdID=9187 Says up to 35 in diameter tires.
Are there 2 (1 pair) of go jacks or 4 (2 pair)?
2 (1 pair)
Should've put that in the original post, huh?LOL! I'll edit it in there.
bump
Bump 2
Make a good X-mas present...
Bump 3...
Goin on Ebay in a few minutes..
Less than 13 hours left...and the reserve has been met. Better hurry!
http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MESE:IT
