396 (402) BBC For sale
Ok guys, I gonna officially put it up for sale.
1965 model 396, (bored .030) Oval port heads Cast iron holley pattern intake Casting numbers are; Block # 3855961 Date C 13 5 (or G 13 5, hard to tell for sure) Heads # 3856206 Date D 3 5 (right head) Didn't take the valve cover off the left head yet. Intake # 3866943 Date D 12 5 Rebuilt by the local machine shop a few years ago. (Stock rebuild, nothing fancy at all). Guessing 30-40K?? Pulled it out of my 72 this spring to put the 454 in. Runs good, the bottom end, and heads are good but it needs gaskets and rings. It burns oil! Carries right at 70 psi oil press, at 2000 rpm or so AFTER it's warmed up. The intake and oil pan are loosely bolted on right now, (thought I was going to have to use them for the 454), but it wouldn't take a lot to make it run if somebody wanted to hear it run. Asking $500 OBO for it.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey Last edited by 454_72_4X4; 12-19-2004 at 10:46 PM. |
Senoir Member
Sounds like a good price, I would be interested if shipping price is affordable. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
Weekend Warrior
it's worth that...a core is worth about $300 - bare block at least in the northeast it is (454 core is worth more...) freakin racers blowing them all up so we can't use them
why is it burning oil @ 30K-40k??? that seems a little odd to me but even @ .030 over you can still go more with it. they can get about .090 over (which is basically a factory 402 (396 that is .030) and bored .060)
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 12-19-2004 at 11:00 PM. |
Out draggin'
I think that is a fair price. If you were closer I'd buy it as a spare...
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
Updated and officially for sale now.
Haven't taken pics yet but I can.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
I may be interested and I'm close enough to come get it. Send pictures to dave3156@yahoo.com. Thanks.
I'll get some pics headed towards ya later today dave3156.
I'll post them here also.
TTT with pics added!
Weekend Warrior
any thoughts on why it would be blowing oil @ 30-40K on a rebuild???
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
#10 | |
It doesn't seem to blow smoke except when you first start it and when you change gears. Guessing it uses about a quart every 150-200 miles. Guessing because I haven't had a speedometer in my truck in quite a while. About all the truck does during the summer is pull the camper to a jobsite and then it sits there and I drive my S-10 where ever I need to go. Winter time I use it to cut/haul wood cause that's what keeps me warm. The motor has been in the shop on the stand you see it on since this spring. It's out of the weather but it is getting dusty and looking at the pictures I see I need to put a cap on the valve cover hole to keep the dust out.
I am really intersted in the 396, I live north of stl 1.5hrs, so i am prolly close to you, i will have the money when i get my tax return, i have part of it now. Let me know what you think, I like the old 396s. Is it a 2 or four bolt main, block this casting number was both head # is 3856206....65-66...oval..CLOSED..396, 97cc chamber
so it prolly has high compression righ? Do you have any other parts avaiable for this motor, like distributer, carbDo you have a water pump???? Lookin to replace the tickin ole, 292 in my C30 ![]() Thanks Ben Cobb |
#12 | ||
2 bolt main. Quote:
I used the water pump on the 454 but I still have the short style pump that was on the motor when I got it. Might be good, might not. It'd be good for a core if nothing else I guess. It can go with the motor. I THINK I have the distributer that came in it also. It's the points type. If I have it it could go too. I ran an HEI in it. I do have a 3310 Holley 750 carb I MIGHT let go with it, (for extra $). I'd have to think about that awhile though. It'd make a good replacement for that 292!! ![]() Like I said I can make it run on the stand, (have to hook it to the cherrypicker so it doesn't decide to take off on it's own ![]()
#13 |
Hey, am definitely interested. I am in southern lower Michigan. beltm@voyager.net, name is Mike.
Do you have the block casting #'s and head #'s? ![]() Last edited by ztoy; 12-23-2004 at 10:57 PM. |
#14 |
Block and head casting #'s are in the first post.
Might be able to work out delivery in a couple of weeks for gas $, (after I get my S-10 back together and make sure it's gonna work out).
#15 |
what part of Mo.? drop me an email
Mike |
#16 |
![]() Join Date: Mar 2003
KB makes a nice piston for a 396 block and a 454 crank, comes out to 434ci. Lots of torque and decent mileage.[for a big block]
#17 |
I have most of my money.
Thanks Ben Cobb |
#18 | |
![]() ![]() Anyway, it's still for sale, Ben.
#19 |
396
Sounds like you have a complete 1965 Passenger car 325 HP 396 engine .The last number in the casting number for the intake an 8 instead of a 3 by any chance? My book shows a 97.1 cc combustion chamber. Nice price on the complete engine .If only I was closer it would be in my barn.Frank
#20 | |
I just went and looked. I think the last number on the intake is indeed an 8. What kinda book ya gettin the info from? I'd like to have one of those books but never got around to it.
How far are you from Grand Praire, (Not sure if thats the right name or spelling)? My boss lives there.
#21 |
book
I have a couple of the "Chevrolet By The Numbers" books by Alan L. Colvin .1965-1969 and 1970-1975 .I use them all the time for parts I sell on Ebay. Great books. Bought them cheap on Ebay. It will also show what trans ,carb, etc the engine came with by looking at the numbers stamped in the block in front of the passenger head .They should be something like TO425LB . Let me know what is there. I like to decode these kind of parts. I am about 3 hours from Grand Prarie ,Tx.
#22 |
is shipping an option?
Keith 70 Chevelle Malibu SS Clone 468/Auto 72 C10 SWB 350/Auto 13 Camaro SS/RS 6.2/Auto |
#23 |
Mine is TO423LB, (you were really close!), and then there is S240109 on the same place up closer to the intake.
Old chevy; I really don't know how to ship something like this but if you can make arrangements or whatever I'd do what I can. Right now I'm at the "sale almost pending" stage, LOL. A couple of guys from KC are wanting to come and look at it.
#24 |
396
325 HP 396 assembled April 23,1965. Had a Powerglide and a Holley 4 barrell from a Belair,Biscayne ,or Impala. By the way ,the first 396's were built starting Feb. 15 1965. That is an early motor. S240109 is the last part of the vin number of the car it came from.Good Luck. Frank
#25 |
Thanks monroe! It's cool to know that info.
To bad it wasn't from a Z-16!
