Old 12-17-2004, 07:05 AM   #1
gregbr
Senoir Member
gregbr's Avatar
4WD indicator switch
Can someone tell me if there is a switch somewhere for the 4WD indicator?? I have a 76 3/4 ton rolling chassis with a 350/350 turbo & transfer case I am putting under a 54 Chevy Panel truck and can't remember where it is/should be.
Also, how can I tell what transfer case I have and if it full or part time? It does have locking hubs if that means anything. Thanks ahead of time, Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 12-17-2004, 09:08 AM   #2
Phuloi68
You have either a np203 (full time) or a np205 (part time) TC. If it's the 203 the indicator switch attaches to the shifter mounting bracket. If it's the 205 it threads into the top of the transfer case. They are two different types of switches and do not interchange.
You can use the search function on this site and find more info about which tc you have.
Phuloi68
Indy survivor
Norwood survivor
Big Sandy survivor
for those who fight for it...
F R E E D O M
has a price the protected
will never know.
Phuloi68 is offline   Reply With Quote
Old 12-17-2004, 12:50 PM   #3
gregbr
Senoir Member
gregbr's Avatar
Thanks Phuloi68, I don't think there is anything mounted on the case anywhere, I will check the linkage area tonight when I get home. Greg
