Got Horsepower?
tranny problem th350
i was driving my truck and when it went to shift to 3rd it started slipping like it was in neutral and would start bogging down and when i gave it some throttle it would start shifting back and forth between 2nd and 3rd, and 3rd would slip like crazy. when i give it enough gas to kick the tranny down it goes into 1st and then shifts to 3rd really hard skipping 2nd. and when i give it alot of gas it wont shift at all. it also is making a rattling sound and i would assumethat is a bad sign. apparently 500 ft lbs of torque and constantly driving it like i stole it was too much for it, 2nd trans this year tranny is only 3 months old with about 4,000 miles last trans lasted for a year with this motor
sorry for long post
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
Careful, they attack...
Yeah, 500ft/lbs with a TH-350 = Kaboom! Did you have the trans built for that much power? They can handle it if you have good parts put in. Otherwise I would go to a TH-400. The 350's aren't meant for that much abuse. You will keep replacing them if you don't switch. Good luck.
Got Horsepower?
yeah i told the guy at the trans shop how much power it had and that i wanted to be able to hot rod the crap out of it and pull my horse trailer with it and he said "oh yeah it can handle it no problem" i guess that shows you how much he knows. i should have put in a manual
I wouldn't be pulling a horse trailer with a TH-350 period. They are fine for 1/2 ton trucks and pulling medium wieght trailers. You should definately go with a TH-400 or a 4L80E. The 4 speed would be way expensive though. Should be able to get a good 400 core and rebuild at a resonable price.
I would not waste any more time with the TH 350. Go with a TH 400, and have it built to the hilt. You will never need another tranny.
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
#6 | |
Got Horsepower?
![]() Quote:
This is probably a dumb question, but have you upgraded the cooling system for the tranny? I can remember when there were alot of Chevy trucks out there pulling everything with 350/350 combos. I was one of them. Had a 70 burb with 406/350 towed race cars with it, stock trailers etc. Never had a problem with stock tranny. It had a big aftermarket cooler plumbed in line with the radiator cooler. I beat on this thing till the body fell off, finally pulled the motor and put it in a blazer,along with the trans.
#8 | |
Got Horsepower?
This, is my BOOMSTICK!
Kick a$$ and take names my man.
![]() ![]() ![]() If he can change his story than so can you. "Ah, no sir, i'm not hot-rodding my truck. No way, no how." ![]() Make them prove it.
Larry Got rid of my projects for now. 1980 Jeep CJ7 1998 Nissan Sentra (my car) 2001 Toyota Sienna (wife's, of course) |
Got Horsepower?
[QUOTE=spencra] "Ah, no sir, i'm not hot-rodding my truck. No way, no how."
Make them prove it.[/QUOTE thats what i told him when he asked me. the he said that if i had he would be able to tell when he takes it apart and then if he tries to get me to pay for it im gonna tell him he can shove it up his a$$ and keep it!!!!
Cheap tow hooks
What do you guys think of my cheap tow hooks pretty flashy huh , i figured chrome is nice and for eight bucks how could i go wrong . :p
#12 | |
Woh, that post came out of left field.
#13 |
Yeah, I would say go with the th400 for hauling stuff. It's meant for hauling and being abused.
THM350 - Medium duty 3 speed trans used from 1969 to 1989, Used in Buick, Olds, Pontiac and Chevrolet cars and Chevy & GMC light trucks until 1987. Generally used in straight and V6 and small block engines. Generally able to handle up to 400 foot pounds of torque THM400 - The THM400 was GM's Heavy-duty 3 speed transmission used from 1964 to 1990. Used on large displacement, high torque engines and engines with towing packages. Generally found in Chevy & GM trucks, cadilacs and large displacement engined, full size GM rear wheel drive cars.
Larry Got rid of my projects for now. 1980 Jeep CJ7 1998 Nissan Sentra (my car) 2001 Toyota Sienna (wife's, of course) Last edited by spencra; 12-18-2004 at 06:15 PM. |
#14 |
Cableguy0 has gone through a few in his truck too. A TH350 should be able to handle a hot street 350 for everyday driving. Now if you race and use nitrous or forced induction and are really twisting the hell out of it, of course it won't last for long. I find it hard to believe you're getting 500 ft. lbs. out of that motor.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
#15 | |
Got Horsepower?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers Last edited by 71chevylongbed; 12-19-2004 at 03:18 AM. |
#16 |
That's one torquey engine you have there. Man, I was hoping for that kind of torque out of the 383 I'm building, now I may be disappointed if I don't achieve those numbers or better.
#17 |
Did you try manually shifting it?
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
#18 |
Got Horsepower?
yeah i tried manually shifting it and it will go into gear but when i give it gas it starts slipping. i took it for a quick drive yesterday and that rattling/grinding noise is worse than before so im guessing that i tore something up pretty good any ideas on what that noise might be?
#19 |
![]() Join Date: Nov 2004
Instead of getting another tranny, get your money back and invest in a 4L60 out of a new chevy truck. With a bowtie TV cable kit and a lock up kit you'll have OD. ALSO, the 700R4 and 4L60 have lower 1st and 2nd gear ratios than the turbo 350....not sure about the 400 though...The lower take-off gears will help with your hauling....also, do you have a 3.08 rear or a 3.73....a 3.08 may have contributed to your tranny frying. I personally think a 3.08 is too high for towing, even with a 350 tranny.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
