Registered Smarta$$
newest chassis?
i have a question what is the newest year chassis has someone put under a 63 to 66 and what did they have to do?
thanx, jim
63 GMC custom going to be slammed ![]() ![]() |
Uhm... no idea what they had to do - but I've seen several for sale that were on the mid 70's chevy truck frames.
Are you wanting to swap yer frame? Just curious as to why? Is yours rotten? Jest curious. -W |
Up to 72 should be a fairly easy swap, after that the frames changed significantly. 73 and up have been done but involves quite a bit more work.
Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
Registered Smarta$$
i been thinking of changing it to 4x4 and was wondering about it
I've never done the swap but have been considering the same thing with a 67-72 4x4 frame under a 60-66. If you have a long box the wheelbase is the same as 67-72. I don't know if any of the body mounts need to be moved. 60-66 4x4s have a "divorced" transfer case but with a 67-72 frame you could use the "married" style. I'd also use the newer front axle with disk brakes.
Bob
