Will a mid 80's front clip fit a '77?
Just wondering. When I get ready to replace my '77 hood and fenders. Will a later model (up to 1987) front clip bolt on? Thanks.
1977 Short Stepside, black, 350/350. Located in Albertville, Alabama. |
ive done the swap the other way and i think you can do it but you will need to do some modification to the hood hinges... also i found the wiper assembly in the cowl need to be swapped out to the same generation of the nose the stubs that the wiper arms are mounted to are a different length the newer ones are longer than the older ones. Also the newer models have a seperate cowl as opposed to a hood that covers the cowl so youwould have to mount that... im sure someone has done it here so do an archives search and see what they say
so many trucks so little time!!! |
A buddy of mine bought a 79 with a mid 80's clip on it, but no idea how easy it was to do that.
Chris |
There is a post on the Colorado K5 sight that tells how to do it. In addition to the wiper drive swap, you have to cut slots in the cowl for the 81-87 hinges.
Oh,you can't buy that new
![]() Join Date: Apr 2000
modifications to the 73-80 Cab are necessary for the hood hinges and the front edge of the frame horns to mount the bumper brackets.. Not a real big deal though. Sawzall, whizzer wheels, sabre saw Etc. I guess a can opener would work if you were desperate ;-) Everything must change though-rad support, inner fenders, brackets Etc. . best to get an entire front clip,DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
