Old 12-19-2004, 09:15 PM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
my guage doesnt work.
how do i tell if my volt guage is bad? it does nothing as of right now.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 12-19-2004, 10:17 PM   #2
67ChevyC10Stepside
ttt
Old 12-19-2004, 10:45 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Volt guage?
You talking an aftermarket voltage guage...or the stock amperage guage?
Old 12-19-2004, 11:04 PM   #4
67ChevyC10Stepside
stock 67-72 guage.
Old 12-19-2004, 11:06 PM   #5
Longhorn Man
look on both sides of the engine compartment in the wire harnesses. You're looking for small black rubber inline fuses on both sides.
You probably have one or two blown fuses.
Old 12-19-2004, 11:08 PM   #6
67ChevyC10Stepside
my wire harness runs on top of the rad support....then through the drivers fender to the firewall....which part of it will they be in? doesn't the brown wire from the alternator go directly to the guage?
Old 12-19-2004, 11:49 PM   #7
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
That's weird, I'm having trouble with mine too. I'm getting power through the fused wire to the gauge so I guess mine's bad. My Granddad installed an aftermarket gauge under the dash so it's cool for now. Is there any way to use an ohm meter or something to check it?
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 12-20-2004, 01:24 AM   #8
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
lol I never had one that worked,figured when the battery was dead,something was broken.Maybe i should check into the fuses as well.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 12-20-2004, 10:06 AM   #9
Huck
Huck's Avatar
The fuses Andy is referring to are on the front corners of the wiring harness---where the fender and radiator support meet. Little bitty things but inline. Usually break just trying to inspect them. Most common cause for gauge failure.
Huck is offline   Reply With Quote
Old 12-20-2004, 12:50 PM   #10
67ChevyC10Stepside
ty
Old 12-20-2004, 03:40 PM   #11
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
I never rely much on the facto0ry gauges, I might put in aftermarket one day but until then, if it don/'t start, somethings wrong
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 12-20-2004, 05:20 PM   #12
john
member #16
john's Avatar
diagram
john is offline   Reply With Quote
