12-19-2004, 10:08 PM | #1 |
3 on the tree problem
I have a 68 gmc with 3 0n the tree and when its cold out its realy hard to shift into first and reverse. So hard that yesturday I broke my shift lever. How can I fix this problem and where can I get parts.
12-19-2004, 10:27 PM | #2 |
10/30/19
There is a list of vendors at the bottom of the page.(67-72chevttrucks.com)Sorry I can't help with the cold shift,mine does the same thing.
12-20-2004, 12:31 AM | #3 |
Junior Member
You probobly have some crud built up in the column. Clean it out and spray some Tri Flow on all the moving parts. Does the trick on the wife's '63.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
12-20-2004, 12:40 AM | #4 |
senior member
i did the exact same thing on my 69 and i cleaned the column out and it works great now. if you want to permanently fix the problem go with a floor shifter thats what i eventually did and i havent regreted it yet
69 GMC bagged |
12-20-2004, 12:51 AM | #5 |
if you cant get it fixed let me no.i might be parting out a 71 3 speed that runs and shifts perfect friday.im in ct,and if you need the column and all the shifter parts i will take 10 plus the shipping.only if its parted out.lol
mike |
02-17-2005, 10:29 PM | #6 |
How did you finally fix this? Mine is stuck also. It also appeared to start happening when it started getting cold.
Glenn Cumming, Ga (68 C/10 Fleetside LWB 307 (64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty) (2001 Porsche Boxster S - 168 MPH of fun) (2005 Chevy Avalanche Z71 1500) |
02-20-2005, 02:58 AM | #7 |
My grease was gummed up on the top between the shift socket and column. Remove steering wheel and turn signal unit and wires remove shift lever then the socket. Clean and lube with white grease and your're good to go.
02-20-2005, 09:43 AM | #8 |
Got Jesus?
littlemike,
Are you going to part yours out? I have been looking for one and am interested. Also, what color is yours? Does the wheel come with it? Please let me know. Thanks! |
02-20-2005, 10:14 AM | #9 |
I am a Referee of life.
Clean the unit up as stated.You might also find that the shifter bushings on the shift arms of the tranny are shot.I replaced mine and it made a huge difference in the tightness of the shifts also.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
