Old 12-19-2004, 10:38 PM   #1
pritch
pritch's Avatar
S-10 weatherstrip question
I picked some up at the junk yard yesterday, and it goes on real good and all, butit seems too short. Like if it was cut at the bottom, there would be a inch gap or so. Is that right? Or is it short because this is on a Panel, with the square door corner?
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 12-20-2004, 02:42 AM   #2
ChevyDude
Not mine that I got from GMC Pauls. Fits perfect on one side with no trimming and was 2" too long on the other side....so I trimmed.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 12-20-2004, 02:50 AM   #3
grebus1
grebus1's Avatar
Hey Pritch, how did the S-10 seals work on the upper rear corner of the door frames (with the 90 deg. angle)? I've got a Burb and have been considering using the S-10 seals, but have not heard from anybody with a Burb/Panel that has used them.
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 12-20-2004, 07:44 PM   #4
purple gas
If you had to cut a mitre for your 90 there's probly some type of glue available to make it look & work ok. Getting 2 nice 45 deg cuts might be the hardest part. And another thing,,Why is there no key to make that little circle thing for degree's?
purple gas is offline   Reply With Quote
Old 12-20-2004, 07:56 PM   #5
bagged91
Out draggin'
bagged91's Avatar
HUH?!? S-10 weatherstripping for the doors??? Tell me more............
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 12-20-2004, 08:37 PM   #6
ChevyDude
You do not have to cut the 90's...I just pushed the S-10 weatherstrip up hard into the corner and continued my way around. One door can be completely installed in less than 10 min.
Alex
Old 12-21-2004, 12:45 PM   #7
grebus1
grebus1's Avatar
Hey Bagged, check out these other threads for more info:
http://67-72chevytrucks.com/vboard/s...highlight=S-10
Old 12-21-2004, 01:52 PM   #8
JJR
JJR's Avatar
Pritch, the seals pulled from an S-10 will be short due to the size difference between the door size off an S-10 vs full size. The aftermarket seals come long (for an S-10)and require trimming to install. If you want to keep the used seals, I would just get another foot or so of seal to fill in the gap.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 12-21-2004, 11:39 PM   #9
pritch
pritch's Avatar
Ya-that's the answer I was looking for. When I grabbed these up, It was just kind of an experiment to see if they really would work, not that I had any doubts, of course. The square corner is a little weird, but you can't see it from the outside and it's not to noticeble on the inside. These will do for now, but I'll get new one's for permanent.
'68 Panel
'68 C-10
Ol' Green
