Old 12-20-2004, 02:01 AM   #1
Russell
Professional Grade
Russell's Avatar
Electric hubs?
Hey guys!
I'm about to make the swap to 4x4 here... Now, I am a bit concerned about the hubs on the front axle here... I have a set of wheels from a 2005 GMC 2500 HD (the alloy wheels) and really don't want to bore out the caps for the front hub. How (un)reliable are the electric hubs, and what would it take to install them? How much more than a 14 bolt FF hub would stick out?
Thanks!
Russ
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-20-2004, 07:57 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
This is a new one for me, electric hubs??? Do you mean auto hubs?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-20-2004, 12:14 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
No, I think they use electric heaters to expand a gas or fluid, which engages the hubs. A buddy of mine says he had them (stock) on his '88 K20 and they could take several seconds to heat up enough to engage in cold weather... and in a creek crossing, they could cool off enough to disengage! Hearing that, they would not be my first choice...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-20-2004, 12:45 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Sounds like the CAD, center axle disconnect?
Old 12-20-2004, 12:51 PM   #5
Mudder
Mudder's Avatar
I've never heard of em, but then theres lots of new stuff out there I don't know about.
Mudder is offline   Reply With Quote
Old 12-20-2004, 12:59 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Hmmm, could be, obviously I'm not familiar with this application and may have heard wrong...
In that case, are the hubs always engaged?
- Mike -
RIP El Jay
Old 12-20-2004, 01:32 PM   #7
1969 GMC
1969 GMC's Avatar
Russ,
what front axle are you using? Maybe that could help us out a little more.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-20-2004, 02:52 PM   #8
Russell
Professional Grade
Russell's Avatar
Dana 44 from a 3/4 ton 78
By electric I mean the setup that heats up the axle to engage the lockers. I do live in an area that gets extremely cold (colder than -40 F) so that may be a problem....
I just wanted to avoid having to get the cap bored out to fit the axle's hub through it :p I guess I can if I have to
Old 12-20-2004, 09:26 PM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
post a pic. That should be an external hub design "big". Unless of course it's from a full time 4wd truck then it should have drive flanges nothing to lock.
Old 12-20-2004, 09:49 PM   #10
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
You guys are getting different systems confused.
Hopefully, this will help….
Pre-1981 - trucks had manual locking hubs unless equipped with a NP203 fulltime tranfercase. Then no hubs at all…only a silver cap covering the hub bearings.
1981-1987 - C/K (1987-1991 R/V old body style) models had either manual locking hubs or automatic locking hubs.
1988-1994 GMT400 - newer body style IFS trucks had a thermal electric front-axle disconnect. (not locking hubs but the same principle…. The thermal disconnect, separates the axle(s) from the ring gear) Basically, when the tcase lever is moved a button is grounded and the front axle disconnect heats up a solid substance and turn it to a gas allowing a shift fork to move and connect with the front axle shaft engaging 4wd.
1995- present GMT400 and GMT800 – had fully electric front axle disconnect….no chemistry trickery with gases here….The electric motor to allows the shift fork to engage the front axle(s). Not very reliable I must add.
This is not the same as electric shift transfercase! Which, are even less reliable.
DirtyLarry is offline   Reply With Quote
Old 12-21-2004, 07:19 AM   #11
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
That sums it up, I'll never buying anything newer than a 72!
Russell, your stuck with your big hubs.
Old 12-23-2004, 02:00 AM   #12
Russell
Professional Grade
Russell's Avatar
Hmm, I guess I'll just run a set of steels until I figure out what I am gonna do with the wheel caps then
