Active Member
Vin Trouble
Well I picked up what I think to be a '68 GMC LWB from Fleetside72 this weekend. I am having trouble deciphering the VIN- CS2590D PC3227B. Can anyone out there give me a hand? I would post a pic of the vin plate but I think the pics I have are too large.
Thanks, Paul |
re
1971 Shortbed 350/350 w/ Posi-traction 3:73's 1996 Chevy Silverado TJ in Springfield, Virginia Likes old Chevy trucks Drinks Miller MGD ![]() |
Active Member
Thanks,
I went there but the numbers I have don't jive with whats on that page. |
Resident Curmudgeon
![]() Join Date: Dec 1999
GMC VIN's are not sequenced the same as Chevy. Gohere
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Active Member
Alright that clears up some of it. CS259OD PC3227B= 2 wheel drive, v6, 3/4 ton, Wide Side, Pontiac, 1967. The 59 is the only part that doesn't work out.
Thanks guys, Paul |
re
Where you at in MN?
Active Member
Just south of the Cities in Lakeville.
re
I grew up in Foley near St. Cloud
Active Member
Thats a nice area.
CS2590D PC3227B
C= Conventional S = six cylinder 2= 3/4 ton 59= a 54 inch dimension from cab to rear axle....they just did it like that. 0D= wide side box P=Pontiac asembly plant C= 1967 Rest is sequence number Are there marker lights on the side of this truck? I had one truck I saw have the B at the end also. From what I can figure..its a left over type way that GMC trucks produced in the United States were given a GVW rating...typically B meant 3/4 ton. In older 62-66 trucks thats the way GVW rating were done. So that's what leads me to think that way. It works in this case.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Since the pics are too big to post? could you e-mail be a picture of your glove box option sticker and the vin plate to roger0080@netscape.net? I'ld like to see this.
I have a picture of an option sticker with a "B" on the end of the VIN, but of course, I cannot readily find it. Dang. Thought I was seeing things when I first saw that (wasn't perfectly clear photo). Rod, are you saying that for this GMC VIN that they stuck the cab-to-axle in the VIN? That would have to be the weirdest I've seen on here. Wonder what the MODEL= looks like then. The 2 and B in this case would be redundant info in the VIN.
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
Yep the 2 and B are redundant in my opinion also.
Let give a stab at a model number and see what happens.. How's this one look CS25934 or CS2590D one other possible way is C9S25934 But I haven't seen too many that last way...but its a GMC. So? I'm guessing the first one. I figure thats whats there. I'm guessing that the year is not in this ones model number code. Lets hear about it.
#13 |
If you'd like to post the pics...email them to me and I will resize and post them for you.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
#14 |
Active Member
Unfortunatly the glove box sticker is gone. Was there such a thing as a heavy 3/4 ton? This truck looks like it has a Dana 60 with some very beafy leaf springs. This truck also has a '70 chevy front clip and hood. Blue Beard whats your email? I'll send you some pics.
Thanks, Paul |
#15 |
Rod, I have a picture of a 1967 Oshawa funky VIN, funky Model:
VIN Number: C9S1471<can;t read> MODEL# C9S10934 Still look'n for the B vin... Why is GMC so all over the board with this stuff while its counter-part Chevrolet is more consistent through those years? sigh.
#16 |
Thats a 67 GMC..it was fairly common for GMC trucks built in Canada to have that 9 after the First C. It designated that the truck was built in Canada. You can see it was buit in Canada by the number 1 in the assembly plant position...Oshawa Plant in Canada....
C9S1471 < Thats last number 1 being the assembly plant position. C= Conventional 9= GMC Canadian Built S= Six cyl 1 = 1/2 ton 4= fleetside box 7= 1967 1= Oshawa assembly plant. Its sort of like the 72 vins where a second letter C meant Chev while a second letter of T meant GMC CCE142 CTE142 start like those above in 72 only for 1/2 ton 2wd. Your model number MODEL# C9S10934 C= conventional cab 9= GMC Canada 1= 1/2 ton 09= 54 inch dimension from cab to rear axle.....you'll notice GMC and Chev used different numbers to represet 54 inches,..while GMC used code 59...chev model number used code 09 34= fleetside Works out all pretty simple once you see them all a few dozen times. That last letter dosent show up often...but I have seen it.. if it were in vin in your case it would have been a letter A to represent 1/2 ton GVW at the end of the vin not the model#. so B = 3/4 and C = 1 ton and so on upward as the GVW's climb.
#17 |
[For Rod]
Here is a listing on e-bay that has an "A" at the end of the VIN. No picture but the seller states the VIN as: CM159ODPC5644A Here is the link: http://cgi.ebay.com/ebaymotors/ws/eB...tem=4526048127
#18 |
CM159ODPC5644A I see a pic of the truck..and its a 67 GMC...no pic of vin plate but anyway
C=- conventional cab M= V6 1= 1/2 ton 59= cab to rear axle is 54 inches OD= wideside P = pontiac assembly plant C=1967 5644= sequence number A= GVW range of 1/2ton see the pattern of the GVW range at the end of the vins..above trucks vin is a 1/2 ton hence A.. way the threads up the truck had a B at end and it was 3/4 ton..hence B is 3/4 ton.
