Does anybody have any good pics of a stepside, minus wood, but with the crossbeams? I have mine apart, and I know where most go, but not positive on all. Only took me about 3 bolts to totally remove bed from truck. Most of beams are pretty much gone. Biggest question is how many 2" thick beams -vs- how many 1".
Also, do the side rails (ones that bolt wood floor down, you can buy stainless ones) unbolt, or are they welded from factory? I found 1 bolt so far (haven't dug too deep yet) but it appears to be a fender bolt. ------------------ Jeff Scott '70 GMC Stepside, Short box '67 Camaro '63 Nova '92 GMC typhoon
Jeff Scott '70 GMC Stepside, Short box '63 Nova '92 GMC typhoon '95 Tahoe |
![]() Join Date: Feb 2001
the angles on the sides come with the bedsides. they are welded. I dont have any 1" beams on my bed. I have 5 cross rails I think, maybe 4 without looking.
------------------ 67 stepside 4x4 Owensville MO mudder67@hotmail.com |
I have been trying to figure out the same thing. The LMC catalog says 5 plus the rear sill, the third from cab is one inch, Mine only has four (third from cab is one inch) plus the rear sill and the replacement bed I bought has four also so I was thinking four. Who knows for sure?
------------------ Hoboken, N.J.(home)/ Washington, D.C.(work)
Hoboken, N.J.(home)/ Washington, D.C.(work) |
Just a tip, If you need the one inch piece try going to your local sheetmetal fabricator to get one. I got one made that way fairly cheap.
------------------ 1969 Chevrolet Custom Camper 20 350/400 70k original miles They have the Internet on Computers now? --Homer Simpson Gee_Emm's Page Vote for my truck to be on the label of a bottle of Jones Soda!!! ![]() |
The only place i can think of for a 1" cross sill would be directly over the rear diff.....its been a while since i had a step box apart! The longhorn had some 1" sills in the middle(3 I think).....69 longhorn.
http://community.webshots.com/user/hotrodhorn |
That is what I am thinking also. 1 1" piece, and the rest 2"
I bought some 1" x 2" box, and 2" x 2" box tubing. Making my own rails. But wasn't sure because old ones were attached by only gravity. ------------------ Jeff Scott '70 GMC Stepside, Short box '67 Camaro '63 Nova '92 GMC typhoon
The short step side bed bed has (3) 2" cross pieces, (1) 1" cross piece plus the rear member for a total of (5) cross rails. I had the local sheet metal shop make up my 2" and 1" cross rails and they turned out pretty good. I did have to weld the support pads on and drill the holes that were needed. It was
a decent way to go and I saved some money doing it this way. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Thanks Jim...
