Old 12-21-2004, 02:20 PM   #1
nosto
Flamin' Bass
nosto's Avatar
Whistles while you drive....can't stand it!
Now that the weather is getting a little cooler I'm driving with the windows up. What I notice the most is the whistling from the vent windows. It's driving me crazy!
I've replaced all the rubber gaskets, felt and seals, re-seated the glass and the vent lock/latches are tight. But I still get whistling. This summer I tried to find out where it was coming from by covering all the outside vent window rubber areas with masking tape and driving. It was quiet! Then I gradually removed the tape one piece at a time until I heard the whistle. Unfortunately, I still couldn't pinpoint where the whistle came from.
Anyone have suggestions or tricks to take care of this annoyance? Please - Nobody tell me to go with one-piece glass - I LIKE the vents!
Thanks,
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 12-21-2004, 02:54 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Somebody has to do it, it just as well be me.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 12-21-2004, 03:01 PM   #3
Pilgrim
Are the vent handles tight enough? Try washers/shims.
Bob
68 C20 Camper Special
Pilgrim is offline   Reply With Quote
Old 12-21-2004, 03:02 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
I have to ask. Does it only whistle while moving? If not, it may be the voices in your head!
If only while moving, the US Gov. issues shims for this. Depending upon your needs, they range in cost from a penny to a quarter and can be found at any bank.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 12-21-2004, 05:14 PM   #5
jhow66
jhow66's Avatar
What tune does it whistle? Just kidding. Try this: Close everything tight. Turn heater blower on high. From the outside take some soapy water and dab around the vent window-leak should show up as a bubble. If this fails change channels-might be whistling a differant tune. (LOL-still just kidding)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-22-2004, 02:08 AM   #6
muddpile
muddpile's Avatar
Is it the opening feature or the look you like? If it's just the look, I'd use black RTV silicone on the rubber. Use a tiny bead and you'll never know it was there, except for the lack of noise. I like the look of the vents, but never open them. This is likely what I'll do.
muddpile is offline   Reply With Quote
Old 12-22-2004, 11:15 AM   #7
RShaips
I feel your pain! I bought two new vent windows just so I could avoid this problem, now the drivers side whistles like crazy, it is making me crazy ! I like the soap idea I am going to try that , maybe then I can pinpoint the leak.
RShaips is offline   Reply With Quote
Old 12-22-2004, 12:29 PM   #8
ChevyDude
Go to electric 1 window set up from:
http://www.a1electric.com/Merchant2/...ct_Code=GM49-K
Maybe this is the answer???
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 12-22-2004, 01:01 PM   #9
nosto
Flamin' Bass
nosto's Avatar
Thanks for the replys -
Yup, I had clear packing tape on for a while, except I DO like to open the vents, so I think I'll try jhow66's bubble maker idea. Besides, I have to leave one vent unlocked all the time because my door solenoid remote unit is acting flakey, sometimes it pops, sometimes it don't. Yes, I have a 911 cable, but have to lay on the ground to use it.
Rick Olson /nosto/
Galloway, NJ
1982 HD XLH-1000
Old 12-22-2004, 09:38 PM   #10
purple gas
Just a thought.. In my obsession with all things heater/ ventilation realated I was thinking that our trucks, unlike slightly newer vehicles don't seem to have any exit vents for the cab. Newer vehicles all seem to have someplace for air to escape so the ventilation system can "flow through". mid '70's trucks had a black plastic vent inside the door jam. I'm thinkin if a person put some type of vent with a one-way flapper type valve in an inconspicuos place it would let the air out in a controlled way. This would stop the air from having to sneak out any place it could , as through vent seals etc. What do you think? It would also improve heater air flow volume. Also, your problem may not be eveident when the truck is parked because the cowel vent area is a natural high preasure area. As speed increases air is forced into the cowel and gives a bit of "boost" to your heating system. If you've ever driven a truck with a blown heater fan, you'll know becasue if you drive fast enough you can feel air come through the defroster/heater. ( Not recomended)
purple gas is offline   Reply With Quote
Old 12-22-2004, 11:10 PM   #11
me3
hart
Well totaly off subject When I bought new Tires for my blazer I got the most grip I could fine. the Idoit that was selling them to me told me I didnt want them because they had to much road noise. I told him I have shot glasspacks and A loud radio. so.. anyway Id recomend ether of them. but my truck on the other hand has a hole through the floor I could throw a cat through so I dont have to worry about a whistle. Its just falling through.
me3 is offline   Reply With Quote
Old 12-23-2004, 01:31 AM   #12
purple gas
LMFAO. It's also a good way do jestison your beer, or whatever when the cops are pullin you over. (also not hightly recomended)
Old 12-23-2004, 01:46 AM   #13
me3
hart
Thats why Im putting In one of those 6 pack consels, just dont know what to do with the other 18.
Old 12-23-2004, 10:23 AM   #14
RShaips
Speaking of holes in the floor ! My wife and I flew back to St. Louis from Colorado for my 10 year High School reunion, we had been married about 1 year.I used an old 71 Ford truck that I had given to my dad to use while I was working in Colorado to drive downtown to the reunion. On the way there my wife was putting lotion on her hands and dropped her ring and it fell thru the floor onto the highway while I was driving 70 MPH in the fast lane in rush hour traffic ! She screamed stop! I said yeah right, needless to say it was gone ! the good thing is she took insurance out on the ring two days before we left!
Old 12-23-2004, 02:16 PM   #15
me3
hart
ironic huh 2 days before.
