Old 12-21-2004, 02:31 PM   #1
robert wright
rear gears?
I picked up a nice 87 stepside silverado 2wd last fall. It's got the 305 tbi with 700r4. It's not a powerhouse, but then again it gets great gas mileage. Right now it's covered up under 2 feet of snow.
Anyone know of an easy way of determining what the rear axle ratio is without opening up the rear? I've heard of rotating the driveline 1 turn and counting the revs of the rear wheels. Any other suggestions?
bw
70 chev short/fleet:son's hotrod w/tickets to prove it
69 gmc short/step: project in pieces
87 chev short/step: still thinking about
2000 gmc xcab/step: daily driver
robert wright is offline   Reply With Quote
Old 12-21-2004, 03:13 PM   #2
davidt
davidt's Avatar
If you have a tach u can use rpm, speed, and tire height to determine the axle ratio.
Here is a link with several calculators that can help u. www.csgnetwork.com/automotiveconverters.html
davidt is offline   Reply With Quote
Old 12-21-2004, 04:58 PM   #3
1FaastC10
1FaastC10's Avatar
i'd almost bet its a 2.73
1FaastC10 is offline   Reply With Quote
Old 12-21-2004, 05:02 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
My '86 lists the rear end ratio in the glovebox. Yours might as well. Mine is a 3.08.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 12-21-2004, 07:07 PM   #5
cliffsta
Stepsides RULE
cliffsta's Avatar
yeah check the dealer option sticker in the glove box or the one in the doorjam.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 12-22-2004, 02:29 PM   #6
loblazer
loblazer's Avatar
I took my serial number to the local GM dealer and my buddy printed me out a build sheet.
loblazer is offline   Reply With Quote
Old 12-22-2004, 02:45 PM   #7
C&C Chevy
C&C Chevy's Avatar
Mine's a 3.08. Betting yours is too.
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 12-22-2004, 07:50 PM   #8
SanitysBane
mine was a 2.73
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 12-28-2004, 02:22 PM   #9
davidt
davidt's Avatar
any luck?
Old 12-28-2004, 05:56 PM   #10
robert wright
No luck yet, can't check the glove box idea until the damn snow stops blowing. I'm guessing it's 3.08, although 2.73 has been suggested. The last article I read said 3.08 was the tallest available though. Were 2.73 available?
bw
Old 12-28-2004, 06:09 PM   #11
RockHQ
ROCKET POWER!
RockHQ's Avatar
Even a 2.56 ratio was available. What insane string of thoughts transpired that idea we'll never know. Those gear sets serve no imaginable purpose and after being retired from their truck duty are most effective as paper weights.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 12-28-2004, 07:43 PM   #12
cliffsta
Stepsides RULE
cliffsta's Avatar
hey hey hey!! I'm glad i got nice and long 2.56, being as with a non-od tranny, it helps gas mileage.
Old 12-28-2004, 07:48 PM   #13
magnethead
7000 #'s of american IRON
magnethead's Avatar
look on the axle- i heard on some axles there'll be a label riveted to the axle somewhere- either the diff cover or axleshafts, and it'll have the ratio on it.
magnethead is offline   Reply With Quote
Old 12-29-2004, 12:22 AM   #14
bloertcher
bloertcher's Avatar
usually the axle tag is gone,but if it survived,it will be on one of the upper cover bolts,you can't miss it if it's there.Honestly,if you want to know for sure,spend a few bucks on a gasket and a couple quarts of gear lube.The ratio is stamped on the ring gear,usually the # of teeth on each gear.You could probably use some fresh gear lube anyways.
bloertcher is offline   Reply With Quote
