12-21-2004, 02:47 PM | #1 |
will 91 k5 bumpers fit 80 k10?
buddy at work has some nice bumpers of his 91 blazer that he said i could have for the '80. will they bolt up?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
12-21-2004, 03:07 PM | #2 |
yeller
No.
I believe the brackets are different, as are the frame mounting points. The bumpers themselves also look different, the 81+ bumpers are more squared off as opposed to the 73-80 more rounded bumpers...at least the fronts anyhow.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
12-25-2004, 11:12 AM | #3 |
Not a bolt on but it can be done. The front of the 90 will have some brackets bolted on the top of frame horn. Little metal work on the 80 frame horns and you can bolt those brackets on.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
12-27-2004, 04:45 PM | #4 |
www.73-87chevytrucks.com
You need to do this for the front:
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
12-27-2004, 08:32 PM | #5 |
so you just have to trim the horns some and everything will bolt up? does the rear bolt right up?
12-28-2004, 06:23 PM | #6 | ||
12-30-2004, 06:29 PM | #7 |
