Old 12-21-2004, 03:57 PM   #1
davidt
davidt's Avatar
c-notch or not
I've finished installing the 4-link on my truck. I was wondering if there was a basic rule of thumb for determining if the frame needs to be notched or not. I understand all the variables to consider like spring rate and ride quality. My truck obviously won't be carrying any cargo in the bed. I would like to avoid cutting the frame if I can but also I don't won't to get the truck together and realize I need to take it back apart to redo it.
davidt is offline   Reply With Quote
Old 12-21-2004, 04:48 PM   #2
Prerunner1982
Prerunner1982's Avatar
you running bags? or what? it really depends on how low.. you want to go..
Prerunner1982 is offline   Reply With Quote
Old 12-21-2004, 05:59 PM   #3
r0lf-
Hotwheels?
r0lf-'s Avatar
Yeah, your gonna have to give us more info on this. Almost all of us still run leafs, soooo... with your 4 link and shock setup we have no idea how much clearance you have. I have about 7-8" drop in the rear and I 100% need that notch. If its the typical 5-6" of drop in the rear, you can get away with not putting it in if you dont haul anything.
Give us some more info.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 12-21-2004, 06:04 PM   #4
SanitysBane
i belive you need atleast 3 inches between the top of the axle tube and the frame.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 12-22-2004, 02:32 PM   #5
loblazer
loblazer's Avatar
I put a 5" flip kit in my Blazer and had to C notch. I had 2" from bump stop to axle. It might have been the old springs sagging some but a small notch is no big deal and easy. I put in a 5" C. I now have new springs to install so may get more clearance back?
loblazer is offline   Reply With Quote
Old 12-22-2004, 02:53 PM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If it has been lowered any more that 4", it will need a C-notch regardless of how it got dropped to get full travel.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-27-2004, 12:38 PM   #7
davidt
davidt's Avatar
I don't have bags, just a straight coil-over kit. I beleive the spring rate is #450lbs per side. I'm not sure the total amount that it has been lowered. If someone could give me a frame to axle measurement on a factory height truck with good springs that would help. Mine has about 2 inches between the top of the tube and the factory stop. I removed the stop and the bracket to put on a lower profile stop like in the summit catalog. I think i could squeeze out about 3.5 inches then. The coilovers are pretty stiff and fully adjustable. I'm planning on running about a 30 inch tall tire so that means I will have to keep the back down low to keep the truck sitting right.
Old 12-27-2004, 12:44 PM   #8
davidt
davidt's Avatar
By the way if someone could send some pics of thier truck with a similar set up it would help. It is a 77 step side. I'm planning on a 30 inch street slick or drag radial to fill up the rear fender. The truck is lowered but not going to be in the weeds. Just looking for a good pro street stance. If anyone is running a similar set up I'd love to see the pics.
Old 12-27-2004, 06:56 PM   #9
SCOTI
SCOTI's Avatar
Try driving it the way it is first & see if it needs a c-notch.
My 74 has the HD leaf option & I have a flip kit + drop shackles for @ least 7" of drop & haven't installed my c-sections yet. Do I need them? @ this amount of drop, yes. Is it driveable @ this amount of drop & w/o the c-notch, yes . .... but it easily bottoms out on sudden dips & bumps.
The point is, everyone told me "you must have c-sections when you do a flip kit" & it wasn't mandatory. Once I added the shackles it is mandatory if you want to put any weight (like a spare tire) in the bed. IIRC, the measurement between the top of the housing end & the lower part of the frame rail is about 1 - 1.5" max.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-27-2004, 07:27 PM   #10
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
Here's my 77' (sorry about the crappy picture) the rear has 31" tall tires
Rear has a flip kit and 2" shackles.. the front has spindles and 2" springs.
Hope this helps
Grande Rojo is offline   Reply With Quote
Old 12-27-2004, 07:30 PM   #11
Grande Rojo
paper or plastic?
heres another pic with rally wheels 285/70/15
Old 12-28-2004, 11:25 AM   #12
davidt
davidt's Avatar
Grande Rojo:
that pic helps alot, what is the rim size and tire size in the first pic? Also, not to have you crawl around under your truck, but what did your measurement end up after the flip and shackle kit from the top of the axle to the bottonm of the frame. Did you c-notch or not?
Old 12-28-2004, 11:26 AM   #13
davidt
davidt's Avatar
By the way... sharp truck!
Old 12-28-2004, 11:18 PM   #14
bloertcher
bloertcher's Avatar
if in doubt,notch it.I notched mine cheap and simple,and you've probably got the stuff laying around your garage.I took a piece of 6" pipe,split it down the middle,cut out the frame and welded in my "half pipes".I then took some 1/4" plate and boxed a 12" section of the frame where the notch is,Clean,simple,and as strong or stronger than stock.
bloertcher is offline   Reply With Quote
Old 12-29-2004, 12:40 PM   #15
davidt
davidt's Avatar
That sounds cool. I think I have seen some pics on here like that. May have been your truck.
Old 12-29-2004, 07:57 PM   #16
Grande Rojo
paper or plastic?
I had to c-notch mine also the axle was a few inches from the frame. I also had to notch the floor of the bed. The center section of the rearend hits the bed floor under suspension travel.
Old 12-30-2004, 11:54 AM   #17
davidt
davidt's Avatar
I don't think my center section will be that close. Do you know what the axle to frame distance was before the notch. Also what size are the rims/tires in the first picture?( the torque thrust not the rally's)
Old 12-30-2004, 04:57 PM   #18
Grande Rojo
paper or plastic?
rear -17x9.5" wheel 275/60/17 tire
front - 17x8" wheel 235/55/17 tire
