Old 12-22-2004, 02:06 PM   #1
ch4x477
ch4x477's Avatar
Question Harmonic Balancer/Vib Damper Bolt size ?
A little while back someone, actually several people here wrote the bolt size for these things stating that buying a long bolt, a couple nuts and washers, chopping the head off the boltetc.... was a good way to "press " on the balancer. Well Im going to give it a try. But I need that size again ! 75 350 guys ! Thanks
77 Chevy K-20 Some engine Tweaks ! 64 C-10 Shes crunched, But a new cab will will come along soon 87 Z28 Fuel injected 350 Didnt need a car, but couldent resist !!
ch4x477 is offline   Reply With Quote
Old 12-22-2004, 02:13 PM   #2
jhow66
jhow66's Avatar
Can buy one almost as cheap
http://www.jegs.com/cgi-bin/ncommerc...44&prmenbr=361
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-22-2004, 02:18 PM   #3
ch4x477
ch4x477's Avatar
I have one but it just barely reaches into crank and i dont want to pull the threads out !
Old 12-22-2004, 04:14 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Thread on the sbc crank is 7/16-20, a tough score in all-thread. If you want to make one get a grade 5 6" bolt, cut the head off and thread the end with 7/16-14.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 12-23-2004, 08:31 AM   #5
ch4x477
ch4x477's Avatar
Thats what I am looking to do ! The kids in the hardware store here (home depot ) arent much help so I needed that size before hand ! Thanks Fred
Old 12-24-2004, 01:08 AM   #6
jimfulco
I use a piece of 7/16x20 threaded rod, a nut, a couple of fat washers, & some grease, along with the big factory washer. I got the all-thread at a local bolt place (look in the yellow pages), but you can get it on-line at www.mcmaster.com (search for threaded rods). If you really want to get fancy, get a thrust bearing (like a throwout bearing, but smaller) & use it between the nut & the washer.
jimfulco is offline   Reply With Quote
