Clutch..?
I think i just fried my clutch trying to pull my cruiser out of the yard.."2 feet of snow".. Wont pull at all now. Its a 1970 6 cyl 3 speed..is it a 10 or 11 inch?. there seems to be a couple of diffeerent throw out bearings to choose from too..anybody got a part number or a good place to get one? thanks.
and just in case.will the turbo 350 out of my junked 75 bolt up? ![]() Last edited by k9ulan; 12-23-2004 at 10:02 PM. |
"Ochre Ogre"
If it has the HD clutch listed on the glove box door it is the 11". You can also look at it through the inspection cover at the bottom. If the pressure plate bolts are right out to the edge of the flywheel it is the 11". If it is 1/2" further in you have the 10".
A short tail shaft turbo 350 will drop right in. If it is 6" long it will work. Any of the longer tails will mean shortening the drive shaft.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
On throw-out bearings chevy only made two short and long,I went through this with my blazer a few years back,whatever you take out replace with same thing,when i went to replace mine the book called for the short so i said ok put it in and tried to adjust and it wasn't right.took it back out and they kept saying it called for the short.Wel come to find out the book as wrong I needed the long for the 3spd.I remember my dad went through the same thing when i was a kid,so just because the book says so doesn't mean it's always right.
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#4 | |
![]() Join Date: Apr 2004
Clutch deal.
on e-Bay. New not reman. You would have to change crossover member to auto one among others things to convert. Check FAQ section, there might be something on the swap.
1968 Chevy 4x4 307 4 speed |
