Old 12-24-2004, 01:11 PM   #1
fire235
Standard trans?
What is a good manual shift trans for a 307 or 350 engine? Also how hard is it to swap from an auto trans to manual shift trans? The truck was originally 3 on tree but prev. owner swapped to turbo 350 auto so the clutch pedal is already in the truck. I am considering manual with floor shift. Any Thoughts?
Have a safe x-mas.
fire235 is offline   Reply With Quote
Old 12-24-2004, 02:38 PM   #2
70short
I am in the process of swapping the old 4-speed out for A TH400. My preference. I like the idea of putting A newer 5-speed from A later model truck. I dont know what is involved. (crossmember attatchment). Good luck!
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 12-24-2004, 04:01 PM   #3
me3
hart
Do a search on t-5 If you want a five-speed. The later model trucks 5-speed has an electric spedometer Which I hear can be pricy to convert
me3 is offline   Reply With Quote
Old 12-24-2004, 04:49 PM   #4
lpaine
lpaine's Avatar
I will be taking the turbo 400 out of my 3/4 ton one of these days -if I can ever find the time- and putting in a Muncie sm-465 4 speed. It has a good reputation, tough as nails they say. You will probably need a drive shaft from a standard trans truck, a manual trans crossmember, clutch pedal and all linkage (z-bar, etc.) Also, you will need to drill and tap a threaded hole for the z-bar into the block (drivers side) unless it's there already. And I beleive the neutral safety wiring will have to be changed to a manual set-up. The low-hump trans cover will have to be changed to a high hump. Can't think of anything else. Best of luck.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 12-24-2004, 04:57 PM   #5
grayw0lf
I'd recommend against the T5. They are a light duty transmission & will not stand up 350. I wouldn't put a T5 behind anything bigger than a 6 cyl.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 12-24-2004, 05:34 PM   #6
69ChevyLB
Active Member
69ChevyLB's Avatar
I swapped out a 3 spd Saginaw with a 4 spd Muncie. Easy swap with no problems. The engine was originally a 307 thap was pulled and a 350 installed.
69 C10 LWB Project
47 Cushman Scooter Project
It is better to have loved and lost than to live with a psycho all your life.
69ChevyLB is offline   Reply With Quote
Old 12-25-2004, 04:12 AM   #7
4x4Poet
If you have $3000 burning a hole in your pocket, search on Richmond 6-speed.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-19-2005, 03:20 PM   #8
Rdrdave
Broke and still trying
Rdrdave's Avatar
What corssmemeber did you use? I just purchased a M21 and need to get a crossmember for the tail. It currently has the 3spd in it. Thanks in advance.
Rdrdave is offline   Reply With Quote
Old 02-19-2005, 07:21 PM   #9
inline6Bill
A classic GM kinda guy
My thoughts:
Hit the following website:
www.keislerauto.com
Either the TR 3550 or T56 conversion would work great. Been thinking about either for my next project.
Old school rap music: a dual exhausted GM 6 with no mufflers.
"If you can find a better vehicle, buy it" Lee Iacocca, Chrysler commercials of the '80s.
"I did. They are called Classic GM pickups !!!"
inline6Bill is offline   Reply With Quote
Old 02-19-2005, 09:09 PM   #10
71Chevy4-speed
Speed Limit = Floorboard
71Chevy4-speed's Avatar
[QUOTE=inline6Bill]Hit the following website:
www.keislerauto.com
Either the TR 3550 or T56 conversion would work great. QUOTE]
I want the T56 bad, but it'll have to wait for awhile.
1971 C20 350, 4-speed - Sold.
1985 K10 350, Built 700r4, Edel 1406, Performer intake, MSD Ign, Hooker Comps, Silverstars, Piaa drivers, LED tails, Toyo A/T 31's, Eaton Posi, the project.
"Build for torque, horsepower will follow"
71Chevy4-speed is offline   Reply With Quote
Old 02-19-2005, 10:32 PM   #11
70short
much nicer to drive with the auto!!!!!!!!!!!!!!!!!!
Edel 600 cfm carb
HEI
shorty Headers
4/2 Drop
"CHEVY RULES"
