12-24-2004, 07:39 PM | #1 |
Professional Grade
2wd headers on a 4x4?
Any chance my headers for a 2wd will fit my 3/4 ton 4wheeler? She'll be running a 2 wheel drive transmission with a divorced transfercase
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
12-25-2004, 12:44 AM | #2 |
I dont see why they wouldnt.....Im running headers fit for a Chevelle.....just takes a lil bit of heat and a BFH or gentle persuader....along with some time an lots of beer.
Truthfully, I think that they will work. I had a set of headers on my 4x2 that I moved to my 4x4 for a little while, and I didnt have any issues.
The Devil 1983 ONE TON 454/400/208 11" of lift on 44's |
12-25-2004, 01:55 AM | #3 |
Professional Grade
Sounds good, cause I've got an awesome exhaust setup on my current 2wd truck, and I really don't want to have to buy a new set of headers and a new exhaust setup, lol
12-25-2004, 03:02 AM | #4 |
i've got a set that came off of my 86 when it was a C10, im gonna try to make them fit. even if there were clearance issues, mine wouldnt be as bad as some, since my front shackles are moved forward several inches.
12-25-2004, 04:50 AM | #5 |
california fill
I run 2wd doug thorley's on my 4x4.. But I had to heat and bend the passenger side set to clear spring shackles... from what Ive gathered, MOST brands of 2wd headers wont fit a 4x4....
pc |
12-25-2004, 03:37 PM | #6 | |
12-25-2004, 05:26 PM | #7 |
Professional Grade
I won't be running a stock t-case, may be able to get around it yet
If not, I guess I'll drop the money for a new kit..
12-25-2004, 09:50 PM | #8 |
if you're running anything offered by GM, you'll have problems. the only way i could see getting around it would be something physically smaller, like an Atlas or something, and even then it probably wouldnt help a whole lot. plus, an Atlas is $$$
12-25-2004, 10:38 PM | #9 |
Mine fits real snug, Ive got an SM465/NP205, my headers are the long tube Hooker Supercomp, with 2 1/8 primaries into a 3 1/2 collector. From there it is reduced to a 3" pipe into dual 3" flows, with dumps just infront of the rear axle. My passenger side header is about 1/2" from the starter, 3/8" from the passenger firewall on the topside, and the exhaust pipe is bent around the t case, so that even with motor torque, there is no rubbing between the two. Like I said though, it just takes a little creativity with a torch, prybar, BFH and some beer. BTW, this is all on a BBC, so if you are running a SBC, you have even more room to work with.
Just my .02$
12-25-2004, 11:06 PM | #10 |
Professional Grade
Probally just don't know the first thing about the 4x4s, but yeah, my exhaust hugs the frame rails the whole way back, so maybe the t-case won't be in the way?
We'll see...
12-26-2004, 01:31 AM | #11 |
Majician
When I bought my new headers the box had 2x4 and 4x4 both listed as applications.
12-27-2004, 10:15 AM | #12 |
It`s the t-case crossmember you need to get around.Takes a 45deg/45deg to get over it.
12-27-2004, 02:24 PM | #13 |
Professional Grade
If it is a matter of just installing a couple 45 degree pipes in, no big deal then... The pipes are totally straight the whole way back, so a guy could easily cut and install the new pipes
