Old 12-26-2004, 04:35 PM   #1
76bonanza
76bonanza's Avatar
Tranny question
Looking for a tranny leak it looks like it might be coming from a connection on the passenger side just under cooler lines but above the dipstick. I think is is the detent cable but not sure.
One what is this conection two could it leak fluid?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-27-2004, 02:23 AM   #2
1972
Majician
1972's Avatar
If it is between the dipstick and the tranny lines it is probably the detent/kick down cable. And yes, it can leak.
1972 is offline   Reply With Quote
Old 12-27-2004, 08:30 AM   #3
76bonanza
76bonanza's Avatar
Any idea how to stop the leak Maybe a gasket or do I need a whole new cable?
1968 c10
lowered 3" 4"
Old 12-27-2004, 12:33 PM   #4
76bonanza
76bonanza's Avatar
So do I just unbolt the cable and yank it out then take off the o-ring and replace it and rebolt it? Do I need to drain any tranny fluid or will none leak out? Also were can I get A new oring local parts storE?
1968 c10
lowered 3" 4"
Old 12-27-2004, 05:38 PM   #5
1972
Majician
1972's Avatar
To get the cable out there is one bolt that holds it in and then you can lift it out of the hole and unhook the linkage. I don't know for sure, but you may have to unhook it from your carb linkage and take the cable out of the bracket up near the carb also. A new cable is $12.99 at AutoZone. Many hardware stores carry an assortment of o-rings if you want to match it up.
Old 12-27-2004, 07:43 PM   #6
76bonanza
76bonanza's Avatar
Cool so it sounds pretty easy. But no coolant will leak out when I remove the cable will it?
Thanks again fow all your help.
1968 c10
lowered 3" 4"
Old 12-27-2004, 07:47 PM   #7
1972
Majician
1972's Avatar
Coolant won't leak out but transmission fluid might depending on the level. It's been a while since I replaced one and I can't remember for sure. Just have a drain pan ready for if it does.
Old 12-27-2004, 07:53 PM   #8
76bonanza
76bonanza's Avatar
Also looking in the haynes manual would this be called the tv cable?
1968 c10
lowered 3" 4"
Old 12-27-2004, 07:53 PM   #9
76bonanza
76bonanza's Avatar
I dont know why I said coolant.
1968 c10
lowered 3" 4"
Old 12-28-2004, 07:52 PM   #10
76bonanza
76bonanza's Avatar
I got a new detent cable as mine was very old my new one has no oring on it or a place for an oring? Any thoughts I have it all apart now?
1968 c10
lowered 3" 4"
Old 12-28-2004, 07:58 PM   #11
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
Yeah man I did one of these on my 86 silverado. When I did mine it did not come with an O ring either. But neither did the one that came out of the tranny. I replaced the old with the new and everything worked like a charm...Later Mike
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 12-28-2004, 07:59 PM   #12
784X4GUY
784X4GUY's Avatar
Oh and yes that it the correct term for it...Later Mike
