Old 12-26-2004, 07:43 PM   #1
Deuce
Deuce's Avatar
Will these headers work on our sbc trucks??
http://www.jegs.com/photos/50068606.jpg
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 12-26-2004, 09:46 PM   #2
gonebad2
Merciless Butcher
gonebad2's Avatar
Those look sweet. I bet they would. They would probably give you better clearance if your truck is lowered.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 12-26-2004, 10:36 PM   #3
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
If they are the mid-length chevelle headers, just do a search on here for them. There should be 5-6 threads discussing the fit and where they can be purchased. ljbear has them on his and he sent me Summit Racing's part # for the Dynomax ceramic coated ones. wlk-86118 Later, ......Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 12-26-2004, 11:05 PM   #4
Deuce
Deuce's Avatar
There is a new set of chevelle 3/4 lenght headers on the market with both a ball flange and a bolt flange all in one for a leak free seal. Think the are Hooker or Headman.
Old 12-26-2004, 11:48 PM   #5
Deuce
Deuce's Avatar
Should a "shorty" header off a 73-9? truck work also??
Old 12-27-2004, 12:43 AM   #6
Bamm
Bamm's Avatar
ball flanged? Sounds like I should know what that is, but I am drawing a blank. Have you got a pic or a part #?
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 12-27-2004, 02:52 AM   #7
Deuce
Deuce's Avatar
These are not the actual headers, but this is the ball flange.
Old 12-27-2004, 02:55 AM   #8
Deuce
Deuce's Avatar
These are the headers except they have the ball flange, which isn't supposed to leak.
Old 12-27-2004, 12:06 PM   #9
Bamm
Bamm's Avatar
Have you got a part # for the ball flanged ones? So the ball flange goes down into the collector a couple inches to stop leaks?
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 12-27-2004, 12:59 PM   #10
Deuce
Deuce's Avatar
My thinking is the "ball flange" gets pulled into the taper of the collector instead of just bolting 2 flanges together. Basically the same systen the factorys use, so it can't be that bad
Old 12-27-2004, 01:02 PM   #11
gunnersm8
it acts like a compression fitting(for the wanna be plumbers out there). personally, i just welded my headers to the pipe and called it good. however, i cant take my heads off worth a damn now, but no leaks...haha
gunnersm8 is offline   Reply With Quote
Old 12-27-2004, 04:55 PM   #12
72BLAZERDUDE
72BLAZERDUDE's Avatar
Flowmaster has a conversion. Summit sells it PN FLO15925 3" collector to 2 1/2 pipe. Looks like you cut off collector flange and weld on new Ball flange kit. A little pricey at $45.95 but if you have leaks all the time it might be worth the bucks.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 12-27-2004, 10:04 PM   #13
Deuce
Deuce's Avatar
I just bought a set of hedman headers part# 68600. Look like they should work awsome!! Just gotta weld in the O2 sensor bung.
Old 12-27-2004, 10:21 PM   #14
NO LONGER DISTURBED KONCEPTZ
NO LONGER DISTURBED KONCEPTZ's Avatar
Well I think my friend told me that the header from a 1st gen camaro will work on 67-72 trucks but I do know that Early Classic is making headers that are mid lenght now.
NO LONGER DISTURBED KONCEPTZ is offline   Reply With Quote
Old 12-28-2004, 12:04 PM   #15
Deuce
Deuce's Avatar
BIG Bucks!!! I bought mine for $160 canadian, I'll weld on the O2 bung then $150 to ceramic coat.
Old 12-28-2004, 12:46 PM   #16
70c10
67-72 Addict!
70c10's Avatar
You can also buy composite material donut gaskets for about $5 pair at the parts store for collectors. My buddy recently did this on my dads new exhaust. No leaks!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
