67 Factory Side or Top Terminal?
How many of you use top post or side post on the battery?
Which one was fartory? Or was it both? Cheers
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
71 was the first year of side terminals for the truck, everything prior uses the top post battery.
Interstate makes a batthery that has BOTH. Works well in colder areas - the top used for jump starts on furds and dudges.
Bob 68 C20 Camper Special |
its all about the +6 inches
most bettery companies make at least one model with both top and side terminals. Makes sence when you consider there are only 3 comapnies (in the states) that make batteries.
They are also cool for Winches, hook the side terminals to the engine, and top posts for the winch for a better contact. |
Found on some that the terminals on top are too close to the fender when installed.
But in your case either should be fine.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
14.1 @ 96MPH
My '70 had top-terminals stock. On the last battery I got (free for life from Firestone
Project1970 - LS1 Swap Complete! ![]() |
hart
Im converting both over to side I have better luck with them
collector of vintage rust
My 71 has one of each!.......must be a rare 70 1/2!
Naw,just another incredible fabrication from my trucks p.o. ! |
There are advantages to both...the side post is way more likely to stay clean. No green corrosion building up, however, when it s\does start, you don't see it, not untill it is way out of hand anyways. You can safely place wrenches on top of a side post, less likely to short out in an accident, very difficult to mess up as long as you use a 5/16 wrench and not a 6 inch crecent or vice grips. They are a total pain in the 12 bolt to hook up jumper cables to, or battery chargers, harder to run a wire straight from the battery for what ever reason you may wanna do it, and there is always some idiot who ruins the 5/16 head with chanel locks thinking he can get it tight.
![]() Mine has 2 interstate side post batteries. |
