Old 12-27-2004, 01:48 PM   #1
roadking
gauge cluster compatability question
i currently have the gauge cluster with just the speedo and fuel gauge in my truck. i have a gauge cluster im restoring with everything except tach and vacuam. will i have to replace the wiring harness to install this gauge cluster or can i run individual wires to the oil, water and temp.? i read on the parts board someone had problems burning up their wiring hareness when they did not switch harenesses?
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
roadking is offline   Reply With Quote
Old 12-27-2004, 03:44 PM   #2
JimKshortstep4x4
Smile
I am not sure why the harness burned up unless it was mis-wired. You can wire individual wires for the gauges but going with a gauge harness sure simplifies things. Also, down the road when problems arise, it is much easier to follow the factory wiring. I would recommend replacing the harness.
Jim
Old 12-27-2004, 06:46 PM   #3
purple gas
Aparently if you just plug in your new cluster, you'll get a smoke show. Don't want that!! There is a detailed schematic of how to convert your wiring so the dash will work But I don't know where.. Have patience grasshopper.. I'm sure someone will post the link on here.
purple gas is offline   Reply With Quote
Old 12-27-2004, 06:50 PM   #4
tom hand
CCRider
tom hand's Avatar
http://www.gmcpauls.com/Tech%20Tips1.htm
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
