Old 12-27-2004, 03:01 PM   #1
cleszkie
cleszkie's Avatar
Looking for Hard Top Pieces
I am in the process of restoring a double wall top and have a couple questions. 1) I have no key for the hatch handle - are there replacement lock cylinders made for these? Are there entirely new handle assemblies out there? I thought I remember reading a thread were someone mentioned new handle assemblies. 2) I am missing the striker plates for the hatch that bolt to the bottom of the rear top opening (plates that allow the hatch to catch on to and remain closed). I have not been able to find these aftermarket. Anyone out there have a set they would be willing to part with? Thanks in advance.
cleszkie is offline   Reply With Quote
Old 12-27-2004, 07:45 PM   #2
Gee_Emm
Go to the hardware store and pick up one of the generic garage door handles, they are nearly identical and require only the inner shaft to be cut down in order to fit.
Gee_Emm is offline   Reply With Quote
Old 12-29-2004, 03:27 PM   #3
badpeanut
Not a bad nut after all..
badpeanut's Avatar
This is NOT what you are looking for (it goes on the hatch)? Unfortunately this and the actuation rods are all the extra parts I have left.
badpeanut is offline   Reply With Quote
Old 12-29-2004, 03:34 PM   #4
cheyenne10
cheyenne10's Avatar
rekey yours
If your handle is in decent shape take out the handle and have locksmith rekey (remove inside cover and it will be obvious how to remove handle only). I had that done for I beleive $12 then come to find out lock was gumed up and ignition key was a match already. They had made an aftermarket garage door type key blank work but this one was setup as GM made it. Worked smooth after that.
Bob
cheyenne10 is offline   Reply With Quote
Old 12-29-2004, 04:59 PM   #5
pound41
ebay item#7944151370 has one of what you are looking for
pound41 is offline   Reply With Quote
Old 12-30-2004, 06:30 PM   #6
cleszkie
cleszkie's Avatar
Parts
Gee Emm - Yeah I thought of that, but I want as original as possible.
Badpeanut - No not the right piece. I have those on the hatch. I needed the catches that mount to the top. Thanks though.
Cheyenne10 - Rekeying may be a good option. I wasn't sure if the locks were rekeyeable or not. I will look into that.
Pound41 - I'm checking E-bay now. Thanks.
Old 12-30-2004, 08:39 PM   #7
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I am the current owner of the rig Cheyenne10 is talking about and the ignition key works better than the keys he had made.
One of the vendors is selling reproduction handles, but I can't remember which one. Check brothers (http://brotherstrucks.com/). FYI, Mothertruckers has the fiberglass hatch for around $385 (no glass or hardware).
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-30-2004, 08:44 PM   #8
vtblazer
vtblazer's Avatar
Let me check, I think I might have an extra pair.
I'll post a pic when I find them to make sure it's what your looking for.
vtblazer is offline   Reply With Quote
