Old 12-27-2004, 08:04 PM   #1
ocbaud
Garage Queen Material
antifreeze smell???
everytime i drive the truck for a little while, i can start smelling antifreeze in the cab and then the temp gauge starts going up quickly. after a while the smell goes away and the temp drops back down.
what is the problem???
the truck still runs great. no performance problems what so ever.
ocbaud is offline   Reply With Quote
Old 12-27-2004, 08:23 PM   #2
79Silv4x4
Workaholic
79Silv4x4's Avatar
heater core?
79Silv4x4 is offline   Reply With Quote
Old 12-27-2004, 08:26 PM   #3
ocbaud
yes, it is only in the cab, but not always.
and could that be the cause of the over heating problem?
also, it seems that a lot of people are having to replace theres recently
Old 12-27-2004, 08:54 PM   #4
ocbaud
no, still the same old heater hoses, but it has only started doing this in the last month. the heater works great too. it doesnt seem to get any hotter when the temp goes up though
Old 12-28-2004, 03:28 AM   #5
ocbaud
after coming home tonight, i popped the hood and took a look around. there is a small area right under the heater hoses on the firewall. not a lot of antifreeze, but enough to have it drip down and make it noticable.
there is NO wet area on the inside of the carpet also.
could it just be the hoses need replaced?? i've never replaced them since i've owned the truck(4 years)
Old 12-28-2004, 03:30 PM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I noticed the same wet spot on my truck over the weekend. It must be an '86 thing...
I am not getting any antifreeze in the cab, so I'm hoping I can just pull the hose, clean everything up, cut a couple inches off the hose, and reclamp it.
As old as those hoses are, I would replace them. You never know how long the PO used them before you bought it, and replacement is cheap and easy. (BTW, despite what the auto parts stores say, the hoses are two different sizes.) That will tell you if it is the connection or the core. Even if the core is leaking, you still need new heater hoses anyway.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 12-28-2004, 11:48 PM   #7
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Welcome to the club, mine started doing that about a week ago. Damnit!
Yes...its an 86 haha
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 12-29-2004, 12:29 AM   #8
bloertcher
bloertcher's Avatar
Lucky succers,mine's an 82,so I've long since dealt with this problem.I didn't think there was an original heater core left in a 73-87!Seriously,that's your trouble,and there's no good news.It's a *****,plain and simple.I have never heard of a good or easier way to pull this one off.Anyone else know?If there's an easier way,I'd love to know!
bloertcher is offline   Reply With Quote
Old 12-29-2004, 12:37 AM   #9
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
Nope not easy I did one in every 73-87 ive had and they have all been tough...Later Mike
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 12-29-2004, 01:34 AM   #10
SanitysBane
hmm..i knew mine was bad, so i pulled it out, couldn't find any leaks, so i put it back in, about a week later is started leaking, so i pulled it back out and put a new one back in. and if that stupid thing goes out again im just not going to have a heater.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 12-29-2004, 01:53 PM   #11
KShortell
KShortell's Avatar
Yeah, I just replaced the heater core last week in my 1986. On the rarest of occasions over the last three or four years, I could smell a whiff of antifreeze, but nearly always no smell at all. When it blew, it was unmistakable.
The worst part is that you can't just inspect it. You have to tear down everything so far to get to it that you'd might as well replace it as to inspect it...
It might be your hoses, though. A heater core leak would not appear below the hose fittings, but at the bottom of the heater box in the cab or, less likely, the A/C evaporator box under the hood.
Good luck!
Semper Paratus
KShortell is offline   Reply With Quote
Old 12-29-2004, 06:32 PM   #12
ocbaud
well, i bought some new heater hoses and a new thermostat to put in. i'll do that later when the truck cools down a little bit
hopefully that will fix it
Old 12-29-2004, 07:18 PM   #13
Destructo
my 85 leaks sometimes under the hoses where they connect to the heatercore, I know why too, its because somebody put two 3/4" hoses on it and one is supposed to be 3/4 and the other is a 5/8s I think?
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 12-29-2004, 07:28 PM   #14
784X4GUY
784X4GUY's Avatar
Good luck with it ocbaud hope that fixes it...Later Mike
