I have a 95 F-350 Power Stoke Diesel that I use at work. Most of the time we leave it running when we are getting in and out but if we are going to be out for a few hours we shut it off. Some times we have to go right back out again and when we try to start it it will crank and crank and crank, and then finally fire up. Some times it will crank and crank and crank and never start. I know this is off topic but there are alot of sharp gear heads here and I hope one of you knows the answer.
Mike |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Could be getting air in the fuel system from a leak somewhere. That's usually what happens when a diesel gets to acting like that.
Or, Powerstrokes are bad about CPS sensors going out. Real bad about it. Upside is they are dirt cheap and easy to change.
huh?
![]() Join Date: May 2000
Yeah, most likely either a fuel leak, or the CPS sensor. My bro in law has a 97 F250 SD with a powerstroke, and he had the same exact problem recently. All he needed to do was replace the CPS. Hopefully that's what the problem is with yours too...pretty easy fix, as Tx said.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
Usually, the CPS gives symptoms driving down the road too, though.
I'd imagine it's a fuel leak. First place to look is the fuel filter housing. It's the part of the system that gets human hands put on it the most, so it's most liklely where the problem lies. I mean, no one ever takes the connections loose under the truck or at the high pressure fittings, it's always the filter. Sometimes, the o-ring gets damaged and goes tango uniform, which lets air leak in when you shut it off. A diesel with any air in it is an unhappy thing. All it takes is a tiny bit of air and you have troubles.
I have seen lots of those seven three power jokes with cracked fuel filter housings...but that doesnt sounds like your problem because you would have a fuel leak at both hot and cold starts...i am gonna go with the module..if that fails repost and i will get the service manual and try and help you out.
2003 yamaha raptor. Stock, but it still hauls!!!! 2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow. 72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon. "dont let yer mind wander, its to little to go places by itself." "Forget the herse, cause i'll never die"-ACDC Back In Black "If It's To Loud, Yer Just Too Old" "I Love Anything Fast Enough To Do Something Stupid In" "Instant idiot, just add beer!!"" |
A good site for that type info is in this link.
http://forums.thedieselstop.com/ubbt...b42&PHPSESSID=
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
#7 | |
