power booster rod question
hello,everyone
my first post,i need to know the length of the rod, coming from the power booster to the master cylinder,this would be the short rod for a 71-72 disc brake set up.if anyone could help,i would apprieciate it. thanks marvin. bolinas,ca. |
Can't answer you Q but...TTT and welcome from Maryland.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
