BK Built
Progess pics on the panel
Well, figured id post some progress pics on up here. So, ive got the mid 80's crossmember up there, got my bags all up on it, waiting on drop spindles. Ive got one side floor almost done, along with rocker replaced, waiting on cab supports. I shaved the firewall and mounted up a power brake booster and tilt steering wheel from a firebird. I cleaned the engine, replaced all seals and gaskets, and got a 140 amp chrome alternator for it. Got powersteering for the truck and a pump and bracket for it. Got the ece trailing arm crossmember and auto tranny crossmember which im gonna turn upside down for my 4" z. I got a full interior out of a 97 s-10 blazer which im using the power leather buckets and a few other things. I plan to notch the rear and Z it this week, and then replace the wood floor with metal, and have a compartment in the back for compressors and batteries, in which i have 2 viair 450's and 2 dry cell batteries, 1 regular and 1 deep cycle. Well, i think there is some more, but ill post some pics now...
BK Built
oh yeah, i got an mini air body saw, and was straightening out the blade, and youll be suprised how many times it will jab you in the thumb with just a tap of the trigger, i did it, 4 times, straight into my hand...
Good job man , HURRY UP TEST DUMMY!
Needs a Big Block
wicked , what do you plan on doin about your inner fender and hood hinges??
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
BK Built
Well, i hope you all enjoy the pics, i know i sure do!!! I got the 3" spindles on, got 205/75/15 tires on it, have the engine and tranny in it, recessed the bumper 1/2", flipped my ECE tranny crossmember over and dropped the center 1&1/4" to match the 4" Z and so have room for exhaust, got the TA x-member in, got it all ground and painted, cut a good sized hole in the core support for my steering box, and so its all good. Got my box tubing for the rear so i should get that going. Enjoy!
Good job , keep it up!
Unending Project
Gotta give you my atta's here too. That is going to be one badass truck. I'll see it this spring at the local gatherings, right?
Piper BTW, drasticwagon, can we see some more of your ride too? |
BK Built
some new pics, it sits lower though, it lays full rocker as the tranny tunnel was on the tranny... hope you like em
http://pic17.picturetrail.com/VOL83...74/87196333.jpg http://pic17.picturetrail.com/VOL83...74/87196217.jpg |
