12-28-2004, 08:13 AM | #1 |
Junior Member
Original Tach, changed to electronic distributor
I installed an original in cluster tach in my 72 K20, but someone before me installed an electronic distributor, in theory should the tach work with this distributor, I also installed the circuit wiring for the tach cluster. Now when the engine starts the tach reads 750 RPMs but sits there no matter how the engine RPM's change.
Bill Toothaker 72 K20 FSLB 63K FS:86 Mercedes 560SL 63 Ford F100 51 Willy's Jeep station wagon w/64 289 Studebaker 68 Honda SL90 1500 miles Chevy 6 cyl street rod 2011 Nissan Murano cross cabriolet Cabins for Rent Lake Winnipasaukee, NH |
12-28-2004, 08:40 AM | #2 |
The tach should work with your electronic distributor. Make sure the tach has 12 volts to it and the case/instrument housing is grounded properly.
Does you distributor have a terminal for the tach connection? Jim |
12-28-2004, 09:43 AM | #3 |
Never enough time!!
We haven't left the garage yet, but the factory tach in the k20 is connected to a HEI distributor and works fine, up to 2500 anyway...that's as far as me and Bry have revved it!!
12-29-2004, 12:09 AM | #4 |
its all about the +6 inches
Sounds like a bum tach to me.
12-29-2004, 12:12 AM | #5 | |
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
12-29-2004, 12:15 AM | #6 |
pretty much the same as my bum brother in law....doesn't work and probably never will.
12-29-2004, 08:17 AM | #7 |
Junior Member
Yes the distributor has terminal marked tach I am checking the 12 volts and ground. If these prove to be OK is their a rebuild for the tach or do I send it somewhere to be rebuilt? With the engine running, shouldI get a voltage or amp reading from the output termial on the distributor?
12-29-2004, 08:51 AM | #8 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
